We currently purchase GL-iNet AR150 routers (GL-AR150 (White) - GL.iNet Docs) and slightly customize the firmware to fit our unique application. We are looking for a person that would be able to convert this to run on the newer GL-iNet AR300m16 router (GL-AR300M (Shadow) - GL.iNet Docs).
If you can post the requirement publicly here I may help.
alzhao, as we have lost our previous developer and I personally am not a dev - I have the previous work available in git as well as a build image that I use. I would love to find a partner that could do this conversion and/or build a version from scratch with similar features and possibly add a few new capabilities.
If it is just simple job I could have a quick check.
