you guys always break transmission on every release. Working on earlier release now its not. Flashed with new image again same (3.105), no luck.
Web page doesnt work ip:9091
          ssl upgrade broke transmission.
Pls wait a few days and we will put 3.201 snapshot on website.
thank you…is there a workaround till then?
3.201 is in snapshot now so pls hold on and just try it.
          Where can I download, link please…
Any known working version number you can provide?
You can download from here
https://dl.gl-inet.com/firmware/snapshots/3.201_beta2/ar300m/
Image is too big (17.7 MB) for this router, fails to upgrade.
Upgrade from 3.1 also fails - screen shot attached.
If you are using AR300M16 (16M Nor flash version), pls try this one GL.iNet download center
