Hi!
I have the following problem: I’m unable to communicate to U-Boot through serial.
My u-boot-env is the following:
root@OpenWrt:~# fw_printenv
lf=if ping $serverip; then tftp 0x80060000 $firmware_name && erase $firmware_addr +$filesize && cp.b $fileaddr $firmware
_addr $filesize; if nand bad; then run dlf; fi; else echo ping $serverip failed; fi
rlf=if ping $serverip; then tftp $loadaddr $firmware_name && erase $firmware_addr +$filesize && cp.b $fileaddr $firmware
_addr $filesize && echo OK!; else echo ERROR! Server not reachable!; fi
dlf=if ping 192.168.1.2; then echo ok; elif ping 192.168.1.2; then echo ok; elif ping 192.168.1.2; then echo ok; elif ec
ho ping 192.168.1.2; then echo ok; elif echo ping 192.168.1.2; then echo ok; else echo ping finally failed; fi; tftp 0x8
1000000 openwrt-gl-ar300m.img && nand erase && nand write $fileaddr 0 $filesize
firmware_addr=0x9f050000
firmware_name=openwrt-gl-ar300m.bin
lu=if ping $serverip; then tftp $loadaddr $uboot_name && erase $uboot_addr +$uboot_size && cp.b $fileaddr $uboot_addr $f
lc=tftp 0x80100000 config.bin && cp.b 0x9fff0000 0x81000000 0xffff && cp.b 0x80100000 0x81000000 0x40 && cp.b 0x80100000
0x81001002 0x06 && erase 0x9fff0000 +0xffff && cp.b 0x81000000 0x9fff0000 0xffff
uboot_addr=0x9f000000
uboot_size=0x00050000
uboot_name=uboot-gl-ar300m.bin
bootlimit=3
bootargs=board=ar300m console=ttyS0,115200 ubi.mtd=5,2048 root=/dev/mtdblock8 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot
-env),128k(reserved),64k(art);spi0.1:2m(kernel),20m(rootfs),106m(data),22m@0x0(firmware) rootfstype=squashfs,jffs2 noini
trd
bootcmd=nboot 0x81000000 0 0
bootdelay=2
baudrate=115200
ethaddr=0x00:0xaa:0xbb:0xcc:0xdd:0xee
ipaddr=192.168.1.1
serverip=192.168.1.2
loadaddr=0x80800000
stdin=serial
stdout=serial
stderr=serial
ethact=eth1
bootcount=4
I use 115200 8N1 for minicom but it still doesn’t work, as seen below. (SNIPPED the middle.)
root@OpenWrt:~# dmesg |head
[ 0.000000] Linux version 5.10.176 (builder@buildhost) (mips-openwrt-linux-musl-gcc (OpenWrt GCC 11.2.0 r20123-38ccc4
7687) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 Sun Apr 9 12:27:46 2023
[ 0.000000] printk: bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] MIPS: machine is GL.iNet GL-AR300M (NOR)
[ 0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
root@OpenWrt:~# reboot
root@OpenWrt:~# [ 197.280372] br-lan: port 1(eth0) entered disabled state
[ 197.302254] device eth0 left promiscuous mode
[ 197.306846] br-lan: port 1(eth0) entered disabled state
[ 197.322368] eth0: link down
[ 201.891174] reboot: Restarting system
�a�U���ѠL)�˖a�KVK�y�i��A��&ʱ*Q���ʩ�H��j 깕y�� � "I��'�
b Y+j ���(ʀ����*���S��էJ��C���ꅺ���ͥ������7��A�J�I�'�I����������:���E���0�,����ݲ�xSʔ�e�+҂�Ұ����0�'�V٩W+џ��٩)ʵJ
�e�+��j���ݱ��������+A���N���D��鬲�鳚�A�)��tX�����҂�Ұ�ڦ'��,'�5�� XV������u���U�������ڱ��Y'����jų�a�����H�� (Vj ��E� �
�K�I��!��C�Ӧ��ݠ����gL����,ikA��Ѡ���5 �Ŭ��d������0�"���LV�� �e�!e�.˕�LSJ� ��,�+����t�����r��P�
��iW����n�͠Z � �a��˵�+�o. ���hz��dZ� �
�e �c�
���Ґ�R�����=����*9�����YW����=��*
�,� ��7�y�
gY �*�����xLʑ�a�� ¸2e� �
���0����-ꂰI0�
�*��Z�����A��A��K�o�������)����Kգz٦�F� %��
<SNIP>
�գ��A���ɽ�Y,2�.�n���̈B�����J���Y
Ѻ��eƪ�0�j
����KŮJ��V�� ��
��O�ٗ"�n]u�)�����(.V�eV��
���0���S ʠ����:�J��C!�R+�����'���
�LZ�� )��e �a�A�K�Š��Კ�դ�� �"�ѡ���'��&�³� (ѕsꂀ�)��H� �b�Ť ��
� ��0.0�000�] L��ux��er��on��.1��17��(b��lde�@bu�ldh��t)��mi��-o��nw��-l��ux��us��gcc�(Op�nWr��GC��11��.0��20��3-��cc��7
� ��.0��00�� C��0 ��vi��on �s: �001��74��MI�� 2��c)���� ��.0��000� MI�S: ��ch��e �� G��iN�� G��AR��0M��NOR���] ��ab��d
[�� ��000�00]�SoC��Qu��co�� A��er�� Q��95�� v�� 2 �ev �
[� ��00��00��In��rd��ot��ou�� or�emp�y -��is��li�� i��tr��
��.0��00�� P��ma�� i��tru�tio� ca��e ��kB��VI��, ��wa�� l�
�es��e 3� by�es.��[ � 0.�000��] ��im��y ��ta��ac�� 3��B,��-wa�, V�PT,��ac�� a��as��, ��ne��ze��2 ��tes�
[�� ��00��00��Z
o�� ra�ges�
[ �� 0��00��0]�� N��mal� [�em ��00��00��00��00��-0��00��00��7ff�fff�
[�� ��00��00��Mo��bl��zo�� st�rt �or ��ch��od��
[�� ��00��00��Ea��y m�mor� no�� r��ge��
[ �� 0��00��0]�� n��e ��0:��me��
��� ��.0��00�� In�tme� se��p ��de�� [��m ��00��00��00��000�-0x�000��00��ff��ff��
[�� ��00��00��Bu��t ��zon�lis�s, ��bi�
�ty��ro��in��on�� T��al��age�: 3�480��[ � 0.�000��] ��rn�� c��ma�� l��e:��on��le=�tyS�,11��00�� r��tf��yp��sq��sh��,jf�
�[ �� 0��00��0]��en��y ��ch��has� ta�le ��tr��s:��63�� (��de�� 4��65��6 b�tes� li��ar��
[�� ��00��00��In��e-��che�has� t
��� �.00�000��me��au��-i��t:��ta��:o��, ��ap �llo�:of�� h��p ��ee��ff��[� �.00��00��Me��ry��12��12��13��72��ava�lab�
e (��81��ke��el��od�� 6��K ��dat�, 7�8K ��da��, ��44��in��, ��4K��ss��105�0K �ese��ed��0K��ma��es��ve��
[ � 0.��00��] ��UB��HW��ig��32��Or��r=0�3, �inO��ec��=0��CP��=1��No��s=��
�[�� ��00��10��sc��d_��ock� 32�bit� at��25��z,��es��ut��n ��s,��rap� ev�ry ��07��15��ns��[ � 0�008��4]��al��ra��ng��el
� ��.0��92�� p��_m��: d�fau�t: ��76��mi��mu�� 3��
� ��0.��99��] ��un��cac�e h�sh ��bl��en��ie�� 1��4 ��rd��: 0� 40�6 b��es��li��ar��
[ �� 0.�876�6] ��un��oi��-c��he��as��
ta��e ��tri�s: �024��or��r:��, ��96��yt��, ��nea�)
�[� �.11��97��fu��x ��sh��ab�� e��rie�: 2�6 (��de�� -�� 3��2 ��te�� l��ea��� m��_i��e_��: ��11��044�275�000�ns
[� ��12��93��pi��tr��co��: ��iti�liz�d p��ct�� s��sy��em���� ��.1��44�� NE�: R�gis��re��pr��oc�� f��il��16��[�� ��14
��65��the�mal�sys��Re��st��ed��he��al��ov��no��'st�p_w�se'��[�� ��20��22��cl��kso�rce� Sw��ch�� t��cl��ks��rc��MI��
�[ �� 0��28��3]��cp��ist�n_p�rta�dr_��sh��as��ta��e ��tr��s:��12 �ord�r: �� 4��6 ��te�� l��ea��
�� ��0.��54��] T�P b�nd ��sh��ab�� e��ri��: ��24��ord�r: �, 4��6 ��te�� l��ea��ine�r)
�0.2�292�� T��: ��sh��ab��s ��nf��ur�� (e�tab�ish�� 1��4 ��nd��02��
[ �� 0��597�6] �DP ��sh��ab�� e��ri��: ��6 ��rde�: 0� 40�� b��es��li��ar��
�0.2��74�� U��-L��e ��sh��ab�� en�rie�: 2��
(��de�� 0��40�� b��es��li��ar)�
�[ �� 0��79��7]��CI:�CLS�0 b��es��de��ul��32��[ �� 0��90��2]��ork�ngs�t: ��me��am��bi��=1��ma��or��r=�� bu�ket�ord��=1��
�0.3��79�� s��as��s:��er��on��.0��200�/01�31)��hi��ip��ou��er��[� ��30��20��jf��2:��er��on��.2��NAN�) (�UMM��Y)��LZ�
�[ �� 0.�385�2] ��io��xp��t ��io��xp��t:�� gp�o(s� ex�ort��ize�72�lo��ed��ma��r ��2)
�� ��.3��949� Se�ial��82��/1��50��ri��r,��6 ��rts� IR� sh�rin��en��le��
[ �� 0��54��5]��ri��k:��on��le ty�0] ��sa��ed��[
�� 0��58��8]��80��00��ua��: ��yS0�at �MIO��x1��20��0 ��rq�� 9��ba��_ba�d =�156��00��is�� 1��50��
[ 0.367956] printk:
console [ttyS0] enabled
[ 0.367956] printk: console [ttyS0] enabled
[ 0.377015] printk: bootconsole [early0] disabled
[ 0.406522] spi-nand spi0.1: GigaDevice SPI NAND was found.
[ 0.412382] spi-nand spi0.1: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.423832] 2 fixed-partitions partitions found on MTD device (null)
[ 0.430411] Creating 2 MTD partitions on "(null)":
[ 0.435442] 0x000000000000-0x000000400000 : "nand_kernel"
[ 0.447611] 0x000000400000-0x000008000000 : "nand_ubi"
[ 0.626510] spi-nor spi0.0: mx25l12805d (16384 Kbytes)
[ 0.631891] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.638553] OF: Bad cell count for /ahb/spi@1f000000/flash@0/partitions
[ 0.645438] OF: Bad cell count for /ahb/spi@1f000000/flash@0/partitions
[ 0.652804] OF: Bad cell count for /ahb/spi@1f000000/flash@0/partitions
[ 0.659658] OF: Bad cell count for /ahb/spi@1f000000/flash@0/partitions
[ 0.667225] Creating 4 MTD partitions on "spi0.0":
[ 0.672246] 0x000000000000-0x000000040000 : "u-boot"
[ 0.681103] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.687751] 0x000000050000-0x000000ff0000 : "firmware"
[ 0.696151] 2 uimage-fw partitions found on MTD device firmware
[ 0.702349] Creating 2 MTD partitions on "firmware":
[ 0.707482] 0x000000000000-0x000000260000 : "kernel"
[ 0.714636] 0x000000260000-0x000000fa0000 : "rootfs"
[ 0.720786] mtd: setting mtd6 (rootfs) as root device
[ 0.727058] 1 squashfs-split partitions found on MTD device rootfs
[ 0.733535] 0x0000006d0000-0x000000fa0000 : "rootfs_data"
[ 0.741114] 0x000000ff0000-0x000001000000 : "art"
[ 1.103018] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
[ 1.795019] switch0: Atheros AR8229 rev. 1 switch registered on mdio.0
[ 1.853943] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[ 1.863930] eth0: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
[ 1.872752] NET: Registered protocol family 10
[ 1.886165] Segment Routing with IPv6
[ 1.890076] NET: Registered protocol family 17
[ 1.894827] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_
netfilter if you need this.
[ 1.908228] 8021q: 802.1Q VLAN Support v1.8
[ 1.917910] PCI host bridge /ahb/pcie-controller@180c0000 ranges:
[ 1.924310] MEM 0x0000000010000000..0x0000000013ffffff
[ 1.929713] IO 0x0000000000000000..0x0000000000000000
[ 1.935324] PCI host bridge to bus 0000:00
[ 1.939569] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff]
[ 1.946712] pci_bus 0000:00: root bus resource [io 0x0000]
[ 1.952486] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[ 1.959495] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.967753] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
[ 1.974010] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 1.981069] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 1.988075] pci 0000:00:00.0: supports D1
[ 1.992232] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.999284] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
[ 2.006185] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x101fffff 64bit]
[ 2.013775] pci 0000:00:00.0: BAR 6: assigned [mem 0x10200000-0x1020ffff pref]
[ 2.366274] ag71xx 19000000.eth: connected to PHY at mdio.0:1f:04 [uid=004dd042, driver=Generic PHY]
[ 2.376722] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
[ 2.395045] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
[ 2.410023] Freeing unused kernel memory: 1244K
[ 2.414747] This architecture does not have kernel memory protection.
[ 2.421411] Run /sbin/init as init process
[ 3.215978] init: Console is alive
[ 3.220043] init: - watchdog -
[ 4.757622] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 4.899061] usbcore: registered new interface driver usbfs
[ 4.904907] usbcore: registered new interface driver hub
[ 4.910484] usbcore: registered new device driver usb
[ 4.927434] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.937706] fsl-ehci: Freescale EHCI Host controller driver
[ 4.945377] ehci-platform: EHCI generic platform driver
[ 4.951221] ehci-platform 1b000000.usb: EHCI Host Controller
[ 4.957169] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
[ 4.965419] ehci-platform 1b000000.usb: irq 3, io mem 0x1b000000
[ 4.991978] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
[ 4.999333] hub 1-0:1.0: USB hub found
[ 5.006487] hub 1-0:1.0: 1 port detected
[ 5.014624] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.034500] init: - preinit -
[ 6.734826] random: jshn: uninitialized urandom read (4 bytes read)
[ 6.944946] random: jshn: uninitialized urandom read (4 bytes read)
[ 7.001781] random: jshn: uninitialized urandom read (4 bytes read)
[ 7.298453] eth0: link up (1000Mbps/Full duplex)
[ 7.311670] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 11.777438] jffs2: notice: (455) jffs2_build_xattr_subsystem: complete building xattr subsystem, 75 of xdatum (9 unch
ecked, 64 orphan) and 88 of xref (38 dead, 36 orphan) found.
[ 11.796211] mount_root: switching to jffs2 overlay
[ 11.806549] overlayfs: upper fs does not support tmpfile.
[ 11.819340] urandom-seed: Seeding with /etc/urandom.seed
[ 12.093555] eth0: link down
[ 12.111106] procd: - early -
[ 12.114897] procd: - watchdog -
[ 12.896489] procd: - watchdog -
[ 12.900389] procd: - ubus -
[ 13.028090] random: ubusd: uninitialized urandom read (4 bytes read)
[ 13.037931] random: ubusd: uninitialized urandom read (4 bytes read)
[ 13.052134] random: ubusd: uninitialized urandom read (4 bytes read)
[ 13.066924] procd: - init -
Please press Enter to activate this console.
[ 14.241714] random: jshn: uninitialized urandom read (4 bytes read)
[ 14.390344] random: ubusd: uninitialized urandom read (4 bytes read)
[ 14.412221] random: ubus: uninitialized urandom read (4 bytes read)
[ 14.534090] kmodloader: loading kernel modules from /etc/modules.d/*
[ 15.087653] urngd: v1.0.2 started.
[ 15.158745] Loading modules backported from Linux version v5.15.92-0-ge515b9902f5f
[ 15.166638] Backport generated by backports.git v5.15.92-1-0-gdfe0f60c
[ 15.631321] PPP generic driver version 2.4.2
[ 15.643209] NET: Registered protocol family 24
[ 15.682464] usbcore: registered new interface driver snd-usb-audio
[ 15.813641] ieee80211 phy0: Atheros AR9531 Rev:2 mem=0xb8100000, irq=13
[ 15.823786] random: crng init done
[ 15.827315] random: 25 urandom warning(s) missed due to ratelimiting
[ 15.934666] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 37.256145] eth0: link up (1000Mbps/Full duplex)
[ 37.262881] br-lan: port 1(eth0) entered blocking state
[ 37.268302] br-lan: port 1(eth0) entered disabled state
[ 37.274162] device eth0 entered promiscuous mode
[ 37.303021] br-lan: port 1(eth0) entered blocking state
[ 37.308435] br-lan: port 1(eth0) entered forwarding state
[ 38.262034] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
What’s wrong with U-Boot?
