Very good, thanks for the clarification.
Great to know. Did this help you in some way? Did you just run:
setenv variableName
For each variable and then saveenv to commit?
No, no setenv/saveenv after erasing, just reboot to u-boot … envvars will then be set to defaults!
Well, I want to add that the new Uboot is way better than the NAND only version shipped with my AR300M. No MTU issues - uploading the firmware is now flawless on Windows. This is the way it should have been on release. If any current AR300M user has this old Uboot, I would highly suggest not testing unknown images on your device without upgrading Uboot to this version.
I did not even solder the board. I paid $1 at the local electronics shop for the UART and 3 female to male breadboard cables and just placed the pins in the provided holes on the board. Worked fine.
How can I do this without going to u-boot console?
What does it actually do?
What are this addresses?
Or can I at least enable netconsole in this u-boot?
EDIT: Not needed anymore, I’ve bought USB-TTL converter and did it from u-boot console.
cyablo
45
Does anyone have a copy of the fixed uboot? The attachement on alzhao*s post seems to be gone and the bin from github still is wrong.
Here? Where? There is no attachment and no link, and as others have mentioned - the file on github is old. It does not support NAND flashing from TFTP (no “nlf” command defined per documentation in https://docs.gl-inet.com/en/2/hardware/ar300m/ ) and the mode switch is not usable without physical case modifications.
alzhao
47
The post is old so links was lost.
But I just verified this issue. There is a problem and pls allow some time to find out. So do not need to change uboot at this point.
I’ll give it a try this weekend, I won’t be able to test this tonight.
Thanks!
Also - webfailsafe enforces a 16MB limit for all uploads, even NAND despite that being a 128MB flash chip.
cyablo
50
This one finally works
Dont forget to set set fw_setenv boot_dev on !
szab
52
Sorry for necroposting, but that comment should be marked as the solution!
Thanks for sharing!
Here are the serial output how it looks like when executing the commands:
U-Boot 1.1.4-gf8f77125-dirty (Sat Aug 14 08:53:11 UTC 2021)
ar300m - Honey Bee 2.0DRAM:
sri
Honey Bee 2.0
ath_ddr_initial_config(195): (16bit) ddr2 init
ath_sys_frequency: cpu 650 ddr 597 ahb 216
tap = 0x00000003
Tap (low, high) = (0x8, 0x26)
Tap values = (0x17, 0x17, 0x17, 0x17)
128 MB
Flash Manuf Id 0xc2, DeviceId0 0x20, DeviceId1 0x18
flash size 16MB, sector count = 256
Power up PLL with outdiv = 0 then switch to 3
ath_gmac_enet_initialize...
No valid address in Flash. Using fixed address
ath_gmac_enet_initialize: reset mask:c02200
Honey Bee ---->S27 PHY*
S27 reg init
: cfg1 0x800c0000 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
Honey Bee ----> MAC 1 S27 PHY *
S27 reg init
ATHRS27: resetting s27
ATHRS27: s27 reset done
: cfg1 0x800c0000 cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
eth1 up
eth0, eth1
Qualcomm Atheros SPI NAND Driver, Version 0.1 (c) 2014 Qualcomm Atheros Inc.
MFR:200,DID:177
====== NAND Parameters ======
sc = 0x87ff62e0 page = 0x800 block = 0x20000
Setting 0x181162c0 to 0x78f1a100
Hit 'gl' to stop autoboot: 0
ath>
ath> cp.b 0x9fff0000 0x81000000 0xffff
ath> mw 0x81000050 0x646f6e65
ath> mw 0x81000060 0x7365636f
ath> protect off bank 1
Un-Protect Flash Bank # 1
ath> cp.b 0x81000050 0x9fff0050 4
Copy to Flash... write addr: ff0050
done
ath> cp.b 0x81000060 0x9fff0060 4
Copy to Flash... write addr: ff0060
done
ath> protect on bank 1
ath>
