Kind of a pre-sales question… Is there an easy (GUI) way to add a port forward, but also a firewall rule that only allows a certain source IP to match the forward?
Our router supports port forwarding configuration, but does not support source IP in the port forwarding option.
Is this something that can be done via command line?
Of course, you can configure this using the iptables command.
Just to clarify, it’s persistent and I still can make other adjustments via the GUI? Is the process for adding non-GUI rules documented somewhere?
