After updating to the 2.271 firmware image for Ar-750 i get frequent deauth from the wireless gateway it is connected to while using a vpn. If I’m not using the vpn my connection is rock solid. I think this is being caused by gl-health, is there a way to adjust the values before gl-health restarts my wireless connection?
Can you just kill it?
just rename gl-health so that the system cannot restart this service.
Then reboot your router.
I did try to disable it in the startup option in luci. When i do this tho i still get disconnected from the wireless but it won’t reconnect automatically. To be honest i don’t know that it is caused by gl-health I’ll try to attach a log. Maybe you can see something in there to help me fix this.logs.zip (7.9 KB)
I didn’t see gl_health from the log.
I suggest you rename the file because it could be weak up by the settings.
Also please try to disable mwan3, luci->network->load balance
It could change network if it failed to check the network connectivity. You can remove all mwan3 configuration or remove it completely.
opkg remove mwan3 luci-app-mwan3
I don’t see an option to disable mwan3 in luci. Also if I’m using a vpn then mwan3 shows all my connections being offline. And like i said earlier if i disable gl-health my wifi will disconnect and sit there saying connecting but never getting there. I realize now gl-health is a compiled binary so probably not able to be tuned, but I’m still wondering why my wifi is restarting every time my vpn does.
Oh, and i forgot to mention I’m still seeing kernel crashes with the 2.271 update. An example:
184250.748961] ------------[ cut here ]------------
[184250.754014] WARNING: CPU: 0 PID: 0 at compat-wireless-2017-01-31/net/mac80211/rx.c:4214 ieee80211_rx_napi+0x130/0x8b0 mac80211
[184250.766255] Rate marked as an HT rate but passed status->rate_idx is not an MCS index [0-76]: 117 (0x75)
[184250.776163] Modules linked in: pppoe ppp_async option l2tp_ppp iptable_nat ath9k usb_wwan sierra_net sierra rndis_host qmi_wwan pptp pppox ppp_mppe ppp_generic nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE huawei_cdc_ncm cp210x cdc_ncm cdc_ether ath9k_common xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_policy xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_esp xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ts_kmp ts_fsm ts_bm slhc nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_irc nf_conntrack_h323 nf_conntrack_broadcast iptable_mangle iptable_filter ipt_ah ipt_ECN ipheth ip_tables crc_ccitt cdc_wdm cdc_acm ath9k_hw act_connmark nf_conntrack act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_tbf sch_htb sch_hfsc sch_ingress fuse ath10k_pci ath10k_core ath mac80211 cfg80211 compat i2c_dev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables x_tables ip_gre gre ifb l2tp_netlink l2tp_core udp_tunnel ip6_udp_tunnel ipcomp6 xfrm6_tunnel xfrm6_mode_tunnel xfrm6_mode_transport xfrm6_mode_beet esp6 ah6 ipcomp xfrm4_tunnel xfrm4_mode_tunnel xfrm4_mode_transport xfrm4_mode_beet esp4 ah4 tunnel6 tunnel4 ip_tunnel tun af_key xfrm_user xfrm_ipcomp xfrm_algo vfat fat ntfs nls_utf8 nls_iso8859_1 nls_cp437 sha256_generic sha1_generic jitterentropy_rng drbg md5 hmac echainiv ecb des_generic deflate zlib_inflate zlib_deflate cbc authenc usb_storage uhci_hcd ohci_platform ohci_hcd ehci_platform ehci_hcd sd_mod scsi_mod gpio_button_hotplug ext4 jbd2 mbcache exfat usbcore nls_base usb_common crc16 mii cryptomgr aead crypto_null crc32c_generic crypto_hash
[184250.996415] CPU: 0 PID: 0 Comm: swapper Tainted: G W 4.4.92 #0
[184251.003690] Stack : 803fb044 00000000 00000001 80450000 804491dc 80448e63 803dc634 00000000
[184251.003690] 804c378c 00000000 00000000 00000003 00000000 800a7924 803e1d4c 80440000
[184251.003690] 00000003 00000000 803e0158 87c09d60 00000000 800a58a0 00000002 00000000
[184251.003690] 80447f70 801fa900 00000000 00000000 00000000 00000000 00000000 00000000
[184251.003690] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[184251.003690] …
[184251.040793] Call Trace:
[184251.043423] [<80071fc4>] show_stack+0x54/0x88
[184251.048029] [<80081dc4>] warn_slowpath_common+0xa0/0xd0
[184251.053514] [<80081e20>] warn_slowpath_fmt+0x2c/0x38
[184251.058891] [<86c25cf0>] ieee80211_rx_napi+0x130/0x8b0 [mac80211]
[184251.065379] [<86fa77f4>] ath_rx_tasklet+0xdd8/0xe3c [ath9k]
[184251.071260] [<86fa4a44>] ath9k_tasklet+0x168/0x1ec [ath9k]
[184251.077039] [<80084984>] tasklet_action+0x80/0xc8
[184251.081998] [<80084340>] __do_softirq+0x250/0x298
[184251.086981] [<8006aac8>] plat_irq_dispatch+0xd4/0x10c
[184251.092293] [<80060bf8>] handle_int+0x138/0x144
[184251.097077] [<80060a80>] __r4k_wait+0x20/0x40
[184251.101676] [<800a2a50>] cpu_startup_entry+0x9c/0xe8
[184251.106917] [<80470bd4>] start_kernel+0x470/0x490
[184251.111864]
[184251.113497] —[ end trace 65d70dcc65d70dcc ]—
[184251.123197] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
I am testing WISP with Openvpn in my side. Let’s wait a while and see.
