@dbbarron Hi
They dev team fixed the issu on the new firmware, so there is no need to install a package.
Just head to official support page for the slate and download the update file and upload it to the router. Please report back if you are still facing problems
I’m using openVPN. I have had this config installed on the 750 for about 9 months with no prior issues. As I mentioned, on this new firmware, this vpn config works fine when I click abort followed by connect.
Here’s a screenshot from today when the 750 failed to reconnect. This is about 7 hours after the wifi source was restored. The 750 had reconnected to the wifi source, but not the vpn.
As usual, I clicked abort, then clicked connect, and it reconnected to the vpn fine. But the 750 can’t seem to do it on its own.
I am also using Nord and want to know if I can replicate this issue quicker.
Are you connecting to the same wifi network when your opvn break? I know that if you connect to another wifi network and the server found that you changed your IP, the server will kick you out.
I am on Nord and not sure when this can happen. I will just wait and see. If you know there is a way to replicate this problem quicker pls let me know.
By chance, does anyone know if the “dropping repeater” has been fixed in AR750S firmware version 3.104? Also, where might I find Travelmate in Luci via the menu when logged in? Thanks in advance for the guidance.
You shouldn’t have to be a network programmer to get a wifi router to work correctly for the most basic tasks. gl-inet needs to take these routers off the market until they get them working correctly, because THEY PRESENTLY DO NOT WORK AS ADVERTISED.
