Hi All
This maybe useful for everyone trying to connect to private openvpn server. The “dev” line in .ovpn file gets truncated during the import. It’s dev tun
in the original file, but becomes just dev
after the import. When after half a day of beating my head against the wall trying to find the log etc, i just started openvpn manually like this: /usr/sbin/openvpn --config /etc/openvpn/ovpn0/blah.ovpn
i got the error: Options error: Unrecognized option or missing or extra parameter(s) in /etc/openvpn/ovpn0/blah.ovpn:2: dev (2.4.5)
@devs I hope you check and fix this
Which version of the firmware are you using for?
If you use an old firmware, could you please upgrade to the latest firmware? For my testing, I hadn’t have this problem in v3.x firmware.
But I cannot reproduce this issue. Not sure what will cause it. Could you please reset to factory settings, and try again?
