I’ve got a Nexus 5x, Galaxy tab s3, and an Acer laptop.
The Nexus 5x and Galaxy Tab S3 - the wifi chips support HT40, however, it depends on the driver supplied by Android and/or the Vendor (LG/Samsung) to enable HT40 mode - two things that can impact - they might configure the WiFi chipset to 20MHz only, and they might set the 40MHz Intolerant Bit (this is how Apple devices can trigger an HT40 device to HT20 only)
WIth the Acer Laptop - they use many different vendors across their laptop line, so it would help to identify the Wireless Adapter (Vendor/Model - for example “Intel 3165”)
In any event, the adjacent networks in a busy area just might preclude wide channel operation - it’s conditional - consider it “up to 300Mbps”
And that’s why I think it’s a problem with the AR-750S, if I unplug the power and Ethernet from it and plug into an original AR750 the link speed shows as 300
Like I said, not a very WiFi rich area
One thing I forgot to mention - if the GL-iNet device is set to 300 (HT40), and using Wifi as the WAN side, it’ll match the bandwidth of the host AP - so if the host AP is running normal channels in 20MHz, the AR750 should match it.
@Exile1975 - John, is this the case here?
I wish it were that simple. I’m using the ethernet for the wan/internet access.
Is anyone able to confirm that the slate does in fact ever report a 300Mbps link speed on the 2.4ghz band? Maybe someone from gl-inet could look into this now that they’ve returned from their holiday?
Did you try other brand router? Would it caused by your PC only support 150Mbps?
Yes, i can confirm that at least two of the devices will show a 300Mbps connection speed connected with other routers.
You are overlapping other channels. in your posted photo the wide channel should be disabled per regulation.
I wouldn’t be surprised if the firmware in chips made in this decade are now smart enough to disallow the OpenWRT hack patch and denying the request for wide channels.
I understand that you’re trying to help, but please don’t, because you aren’t. Have you been able to get a connection on 2.4Ghz that reaches advertised speeds (over 144Mbps) on stock firmware? I’ve switched the two routers so that the 750s is on channel one and the other is now on channel 11. No longer any overlap but still the same.
PS: it seems devices connected to my ar-750 (original) will no longer hit 300Mbps link speed either.
From your posts I have little faith in your technical ability to report your supposed reality so I have great disbelief of any of your posts.
If you posted technical statistics, screenshots, or actual data, my posts would correlate with that.
And from your posts I have little faith in your ability to understand what you think you know. So as I asked, please stay off my topic. I have no interest in dealing with a first year computer science major who has to be rude to make himself feel Superior
Guys
I have a same problem …can’t fix !
I’m behind a router that have very good band like 900Mega but 750s scrape 10/15 Mega with radio 2.4 Ghz … so ridiculus …
How to solve ?
Thanks
indeed Zhaoooo
