Hi! As the title suggests, I have just bought a 750 which works great with repeating wifi networks or with ethernet connections. However, when I try to use it with my Huawei E3372 4G dongle, it sees it correctly but constantly connects and then disconnects. The dongle functions normally when connected to a PC directly.
Any ideas? I’m new to these devices, so not sure what logs or diagnostic info I could provide to be helpful.
Because I am a new user I can’t provide the log as an attachment or upload the whole log, so I am pasting an extract below. The rest just repeats this.
Thanks for your help!
Mon
Sep 23 10:46:41 2019 kern.info kernel: [ 233.158674] usb 1-1: new
high-speed USB device number 32 using ehci-platform
Mon Sep 23 10:46:41 2019 kern.info kernel: [ 233.412457] usb 1-1: New
USB device found, idVendor=12d1, idProduct=14dc
Mon Sep 23 10:46:41 2019 kern.info kernel: [ 233.419438] usb 1-1: New
USB device strings: Mfr=1, Product=2, SerialNumber=0
Mon Sep 23 10:46:41 2019 kern.info kernel: [ 233.426833] usb 1-1:
Product: HUAWEI_MOBILE
Mon Sep 23 10:46:41 2019 kern.info kernel: [ 233.431178] usb 1-1:
Manufacturer: HUAWEI_MOBILE
Mon Sep 23 10:46:41 2019 kern.info kernel: [ 233.816486] cdc_ether
1-1:1.0 eth1: register ‘cdc_ether’ at usb-ehci-platform.0-1, CDC
Ethernet Device, 0c:5b:8f:27:9a:64
Mon Sep 23 10:46:42 2019 kern.info kernel: [ 233.988952] usb-storage
1-1:1.2: USB Mass Storage device detected
Mon Sep 23 10:46:42 2019 kern.info kernel: [ 234.068637] scsi host0:
usb-storage 1-1:1.2
Mon Sep 23 10:46:42 2019 daemon.notice netifd: Interface ‘tethering’ is
disabled
Mon Sep 23 10:46:42 2019 kern.err kernel: [ 234.229336] cdc_ether
1-1:1.0 eth1: kevent 12 may have been dropped
enabled
Mon Sep 23 10:46:42 2019 daemon.notice netifd: Network device ‘eth1’
link is up
Mon Sep 23 10:46:42 2019 daemon.notice netifd: Interface ‘tethering’ has
link connectivity
setting up now
Mon Sep 23 10:46:42 2019 daemon.notice netifd: tethering (17013):
udhcpc: received SIGTERM
now down
disabled
Mon Sep 23 10:46:42 2019 kern.err kernel: [ 234.375390] cdc_ether
Mon Sep 23 10:46:42 2019 kern.err kernel: [ 234.382112] cdc_ether
Mon Sep 23 10:46:42 2019 kern.err kernel: [ 234.388628] cdc_ether
enabled
setting up now
Mon Sep 23 10:46:42 2019 daemon.warn dnsmasq[4732]: no servers found in
/tmp/resolv.conf.auto, will retry
Mon Sep 23 10:46:43 2019 kern.notice kernel: [ 235.099448] scsi
0:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Mon Sep 23 10:46:43 2019 kern.notice kernel: [ 235.113991] sd 0:0:0:0:
[sdb] Attached SCSI removable disk
Mon Sep 23 10:46:43 2019 daemon.notice netifd: tethering (17447):
udhcpc: started, v1.28.3
Mon Sep 23 10:46:44 2019 daemon.notice netifd: tethering (17447):
udhcpc: sending discover
udhcpc: sending select for 192.168.8.100
udhcpc: lease of 192.168.8.100 obtained, lease time 86400
Mon Sep 23 10:46:45 2019 daemon.notice netifd: Interface ‘tethering’ is
now up
Mon Sep 23 10:46:45 2019 daemon.info dnsmasq[4732]: reading
Mon Sep 23 10:46:45 2019 daemon.info dnsmasq[4732]: using local
addresses only for domain test
addresses only for domain onion
addresses only for domain localhost
addresses only for domain invalid
addresses only for domain bind
addresses only for domain lan
Mon Sep 23 10:46:45 2019 daemon.info dnsmasq[4732]: using nameserver
192.168.8.1#53
192.168.8.1#53
Mon Sep 23 10:46:48 2019 kern.info kernel: [ 240.374182] usb 1-1: USB
disconnect, device number 32
Mon Sep 23 10:46:48 2019 kern.info kernel: [ 240.418610] cdc_ether
1-1:1.0 eth1: unregister ‘cdc_ether’ usb-ehci-platform.0-1, CDC Ethernet
Device
Mon Sep 23 10:46:48 2019 daemon.notice netifd: Network device ‘eth1’
link is down
Mon Sep 23 10:46:48 2019 daemon.notice netifd: Interface ‘tethering’ has
link connectivity loss
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 240.988638] usb 1-1: new
high-speed USB device number 33 using ehci-platform
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.250080] usb 1-1: New
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.257119] usb 1-1: New
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.264556] usb 1-1:
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.268881] usb 1-1:
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.461762] cdc_ether
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.529629] usb-storage
Mon Sep 23 10:46:49 2019 kern.info kernel: [ 241.588800] scsi host0:
usb-storage 1-1:1.2
Mon Sep 23 10:46:49 2019 daemon.notice netifd: Interface ‘tethering’ is
disabled
Mon Sep 23 10:46:49 2019 kern.err kernel: [ 241.645914] cdc_ether
enabled
Mon Sep 23 10:46:49 2019 daemon.notice netifd: Network device ‘eth1’
link is up
Mon Sep 23 10:46:49 2019 daemon.notice netifd: Interface ‘tethering’ has
link connectivity
setting up now
Mon Sep 23 10:46:49 2019 daemon.notice netifd: tethering (17447):
now down
disabled
Mon Sep 23 10:46:49 2019 kern.err kernel: [ 241.730174] cdc_ether
Mon Sep 23 10:46:49 2019 kern.err kernel: [ 241.736877] cdc_ether
Mon Sep 23 10:46:49 2019 kern.err kernel: [ 241.743417] cdc_ether
enabled
setting up now
Mon Sep 23 10:46:49 2019 daemon.warn dnsmasq[4732]: no servers found in
Mon Sep 23 10:46:50 2019 daemon.notice netifd: tethering (17997):
Mon Sep 23 10:46:50 2019 kern.notice kernel: [ 242.610099] scsi
Mon Sep 23 10:46:50 2019 kern.notice kernel: [ 242.624436] sd 0:0:0:0:
Mon Sep 23 10:46:51 2019 daemon.notice netifd: tethering (17997):
Mon Sep 23 10:46:52 2019 daemon.notice netifd: Interface ‘tethering’ is
now up
Mon Sep 23 10:46:52 2019 daemon.info dnsmasq[4732]: reading
Mon Sep 23 10:46:52 2019 daemon.info dnsmasq[4732]: using local
Mon Sep 23 10:46:52 2019 daemon.info dnsmasq[4732]: using nameserver
192.168.8.1#53
192.168.8.1#53
Mon Sep 23 10:46:53 2019 kern.info kernel: [ 245.153802] usb 1-1: USB
disconnect, device number 33
Mon Sep 23 10:46:53 2019 kern.info kernel: [ 245.185012] cdc_ether
Device
Mon Sep 23 10:46:53 2019 daemon.notice netifd: Network device ‘eth1’
link is down
Mon Sep 23 10:46:53 2019 daemon.notice netifd: Interface ‘tethering’ has
Mon Sep 23 10:46:53 2019 kern.info kernel: [ 245.748610] usb 1-1: new
high-speed USB device number 34 using ehci-platform
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.012249] usb 1-1: New
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.019248] usb 1-1: New
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.026628] usb 1-1:
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.030962] usb 1-1:
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.361524] cdc_ether
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.526203] usb-storage
Mon Sep 23 10:46:54 2019 kern.info kernel: [ 246.672527] scsi host0:
usb-storage 1-1:1.2
Mon Sep 23 10:46:55 2019 daemon.notice netifd: Interface ‘tethering’ is
disabled
Mon Sep 23 10:46:55 2019 kern.err kernel: [ 246.996963] cdc_ether
So, I have changed to a power supply putting out 2400mA and used a different cable. It seems to be much more stable now. I’m running some tests (downloading big files, YouTube etc) to be sure, but it looks good now. Thank you!
