Often but not every time I have problem stopping an active wireguard connection.
The gui says ‘error timeout’.
I then tried to stop by using ‘service wireguard stop’ and the command never finsishes.
I then added ‘set -vx’ at the top of wireguard script and again ‘service wireguard stop’
The command seems to hang at ‘flock 1000’, see below.
_procd_wrapper
procd_open_service
procd_close_service
procd_add_instance
procd_add_raw_trigger
procd_add_config_trigger
procd_add_interface_trigger
procd_add_reload_trigger
procd_add_reload_interface_trigger
procd_open_trigger
procd_close_trigger
procd_open_instance
procd_close_instance
procd_open_validate
procd_close_validate
procd_add_jail
procd_add_jail_mount
procd_add_jail_mount_rw
procd_set_param
procd_append_param
procd_add_validation
procd_set_config_changed
procd_kill
procd_send_signal
_procd_wrapper procd_open_service procd_close_service procd_add_instance procd_add_raw_trigger procd_add_config_trigger procd_add_interface_trigger procd_add_reload_trigger procd_add_reload_interface_trigger procd_open_trigger procd_close_trigger procd_open_instance procd_close_instance procd_open_validate procd_close_validate procd_add_jail procd_add_jail_mount procd_add_jail_mount_rw procd_set_param procd_append_param procd_add_validation procd_set_config_changed procd_kill procd_send_signal
procd_lock
readlink /etc/init.d/wireguard
local ‘basescript=’
basename /etc/init.d/wireguard
local ‘service_name=wireguard’
flock -n 1000
‘[’ 1 ‘!=’ 0 ]
exec
flock 1000
Do you try the latest testing firmware?
yes, I run 0915 testing firmware.
have to manually change option enable to 0 and reboot in order to disable wg
this is really annoying.
is there any more info I can provide to narrow the problem down?
Please acknowledge this is being looked into.
thanks
alzhao
September 25, 2018, 6:19am
6
Yes. We are investing this problem.
@kyson-lok
I know the old firmware has this issue, but we had fixed it before. I run 0915 testing firmware and test more than 100 times. I can’t reproduce.
Do you have any other operations?
Could you please upgrade with unchecking keep settings and clean up browser cache? Although it is nothing with it.
reflashed via luci to 0915, with keep settings unchecked.
did minimal configuration (ip address of router, wifi SSID).
restored wireguard config file from a backup.
When I try to connect to my home server I get Error timeout in the UI.
No network connectivity.
output from wg command is weird:
root@GL-AR750S:~# wg
interface: wg0
listening port: 41902
root@GL-AR750S:~#
service wireguard stop command hangs.
@kyson-lok
When I changed my endpoint host from a dns name to an ip address I can connect and disconnect successfully.
Granted I have only tried a few times, will continue testing.
Please try to test using a DNS name for endpoint host and see oif you can reproduce these problems.
@manderss99 Coould you PM your WireGuard configuration file to me? Let me check.
sent configuration in message
connection issue was a bug thats been fixed in testing release.
disconnect issue disappeared when I uninstalled privoxy.
Now I have the disconnect problem again, this time after configuring ddns service.
seems like the same issue with ‘flock 1000’
I use 0929 testing version
ddns configuration with personal details removed:
config service ‘Cloudflare_wg’
option service_name ‘cloudflare.com-v4’
option lookup_host ‘hostname’
option use_https ‘1’
option username ‘email’
option ip_source ‘web’
option enabled ‘1’
option password ‘xxxxxxxxxxxxxxxxx’
option domain ‘host@domain’
option check_interval ‘10’
option ip_network ‘wwan’
option use_syslog ‘1’
option interface ‘wg’
service wireguard stop with set -vx:
procd_lock
local ‘basescript=’
flock -n 1000
‘[’ 1 ‘!=’ 0 ]
exec
flock 1000
manderss99:
please look into this, its really easy to reproduce.
Just configure ddns with interface wg and start and try to stop vpn.
I need ddns support when using vpn.
