I have been using the AR150 for about 2 months now. It was working fine till about 2 weeks ago. Since then I’m having a peculiar problem consistently.
If I make any kind of change to the device settings (Wifi hotspot, wifi password, timezone, router SSID, etc), the router becomes invisible to me over wifi. My phone or laptop cannot connect anymore. I have to do a complete system reset.
I tried changing only 1 thing at a time, like just change the SSID. Even then, the same thing happens. Now this did not happen before as I mentioned earlier. I also upgraded the firmware to v2.13 found on the download page. I tried changing 1 setting and again the same problem.
When i use it with everything at default settings, it works. I can also ssh into it. Can someone help me with this?
@xiaoxin Yes I am using the standard web interface, just as I always have.
@alzhao I have already reset it like 10 times. If I make any change, the router goes invisible, and the red light keeps blinking. I have attached the output from the 2 commands you mentioned. The name is currently the default one, since I cannot change it.
Its just like what any normal user would do, changing SSID, password, etc. It used to work flawlessly before, but not anymore. I haven’t made any other change in the hardware or firmware.
@alzhao ok don’t ask me how, but somehow it’s working fine now. I changed settings like SSID, password, channel and there doesn’t seem to be any problem as of now. I’ll report back if this changes.
