I am about to purchase this model but I need to know which ports support POE, is it WAN or LAN?
The reason I am asking is because I will use this device as a repeater so it will look like this:
Internet —Ethernet— Asus Router —Wifi— GL iNet AR150 —Ethernet with POE— Asus Access Point
This means that I will connect the Asus Access Point to the LAN port on the AR150 in repeater mode. Can you confirm if the AR150 has POE capabilities on the LAN port?
Ok, I will use it as POE in only. Can I use the WAN port as LAN port with GL.iNet software only or do I need other software?
The AR150 will receive the DHCP IP from the ASUS router via WiFi so I need to understand if this can be done or if it is needed to happen via the WAN port?
