I bought this router to conserve data when tethering my phone and doing video calls - but just does not work, as a Speedtest shows it is grabbing as much data a possible - is this being resolved and when !
Do you mean speed limiting? Are you using 3.201 firmware?
When I do a speed check using the Windows “Network Speedtest” and get speeds in excess of those set within the router
I was using the latest firmware, it didn’t work, so then reverted back to v150 - neither limited the down or upload speeds.
I just tried firmware 3.201 release and the speed limit works.
Maybe you can flash 3.201 without keep settings and try again.
I have flashed the firmware again and it works, many thanks for your help !
