I have my own ovpn server running on a VPS. I connect the router to the ovpn server and it is successful. The problem is the wifi clients connected to the router do not get any internet access once the VPN connection is established. I run curl on the router and check my ip and it shows that my vpn is working. But nothing on WIFI is getting anything on the internet. As soon as i turn openvpn off, then all wifi enabled devices can get on the internet.
Is there a firewall or bridge that I need to create so WIFI can access the VPN network created?
I posted all on the 16th and found the bug. Would of thought youd reply to acknowledge the issue, but no problem! Thanks for your reply. Sorry if mine was a bit strong!
