I am trying to update the firmware on my AR300M, which is currently running 3.216. On the Local Upgrade page, after selecting the file the screen is stuck in "Uploading ..." and never makes any progress after that. How do I get the firmware updated at this point? Is there another method other than the web UI?
Which firmware do you upload?
4.3.18. The latest available for that model.
I remember about people complaining that it does not work straight from 3.x to 4.3.18
Can you try to upgrade to 4.3.7 before?
Same thing happens, just stuck uploading.
Hi there,
Oddly enough I just dug my AR300M out and wanted to update it before using it again..
There was an online update that allowed me to update to 3.216.
But then I noticed the latest 4.x firmware here GL.iNet download center
I tried the latest 4.3.18 and others from that list and I'm also getting stuck in the same Uploading step..
Have you managed to update to 4.x?
How can we update in another way?
I tried on Chrome and Firefox to be sure..
When I got home from my trip I used an Ethernet adapter to do the uboot upgrade instead. It worked that way, but would never work through the web ui.
