1、刷入gl-inet官方固件以后,安装freeradius时发现,只能安装freeradius3 无法安装 freeradius2
2、安装freeradius3以后,发现无法启动 radiusd
3、使用调试模式 radiusd -X ,发现有如下错误
Error loading shared library libfreeradius-server.so: No such file or directory (needed by /usr/sbin/radiusd)
Error loading shared library libfreeradius-radius.so: No such file or directory (needed by /usr/sbin/radiusd)
Error loading shared library libfreeradius-eap.so: No such file or directory (needed by /usr/sbin/radiusd)
Error relocating /usr/sbin/radiusd: fr_cursor_next_by_da: symbol not found
Error relocating /usr/sbin/radiusd: fr_event_loop: symbol not found
Error relocating /usr/sbin/radiusd: fr_packet_list_num_elements: symbol not found
@alzhao
call~call~call~call~call~
你可以把opkg repo的链接换成LEDE官网的试试。
我试过了 把opkg repo的链接换成LEDE的依旧报错
@kyson-lok @alzhao update lolololol~
@qca9531
更新lede 的源可以啊。
- 修改 /etc/opkg/distfeeds.conf
- opkg update
- opkg install …
root@GL-AR300M:/# cat /etc/opkg/distfeeds.conf
# src/gz packages http://www.gl-inet.com/lede/2.27/ar71xx/generic
src/gz base http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/base
src/gz packages http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/packages
src/gz routing http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/routing
src/gz telephony http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/telephony
root@GL-AR300M:/# opkg update
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/base/Packages.gz
Updated list of available packages in /var/opkg-lists/base
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/base/Packages.sig
Signature check passed.
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/packages
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/routing
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/routing/Packages.sig
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/telephony
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/telephony/Packages.sig
root@GL-AR300M:/# opkg install freeradius2
Installing freeradius2 (2.2.9-1) to root...
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/packages/freeradius2_2.2.9-1_mips_24kc.ipk
Installing libltdl (2.4-2) to root...
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/base/libltdl_2.4-2_mips_24kc.ipk
Installing libreadline (7.0-1) to root...
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/base/libreadline_7.0-1_mips_24kc.ipk
Installing freeradius2-common (2.2.9-1) to root...
Downloading http://downloads.openwrt.org/releases/17.01.4/packages/mips_24kc/packages/freeradius2-common_2.2.9-1_mips_24kc.ipk
Configuring libltdl.
Configuring libreadline.
Configuring freeradius2-common.
Configuring freeradius2.
root@GL-AR300M:/# radiusd -h
Usage: radiusd [-d db_dir] [-l log_dir] [-i address] [-n name] [-fsvXx]
Options:
-C Check configuration and exit.
-d raddb_dir Configuration files are in "raddbdir/*".
-f Run as a foreground process, not a daemon.
-h Print this help message.
-i ipaddr Listen on ipaddr ONLY.
-l log_file Logging output will be written to this file.
-m On SIGINT or SIGQUIT exit cleanly instead of immediately.
-n name Read raddb/name.conf instead of raddb/radiusd.conf
-p port Listen on port ONLY.
-s Do not spawn child processes to handle requests.
-t Disable threads.
-v Print server version information.
-X Turn on full debugging.
-x Turn on additional debugging. (-xx gives more debugging).
