HI,
I tried to flash may custom firmware:
compiled GitHub - domino-team/lede-1701: a clone of lede-1701 and add patches for GL's new devices
and
but it stuck on boot, fixed red led.
It needed a patch for firmware?
HI,
and
how many LEDs light up? I think it should just works.
only red…
I fixed compiled version, my error on selected packages.
Official lede instead hangs!
I will try official LEDE firmware.
We tested the official LEDE firmware and it works just fine. Not sure what is the problem in you side.
<span id=“result_box” class=“short_text” lang=“en”><span class=“”>I’ll have to try it again, thankyou!
</span></span>
Any instructions on installing official lede?
And is this lede from gl-inet.com or from the official lede website?
You can use our compiled firmware. You can also use firmware from LEDE/Openwrt. The process is the same.
I am unsure how to go about installing lede/openwrt there is no guide to follow
I am having a huge problem adding a network interface. The web ui just tells me
Form token mismatch
The submitted security token is invalid or already expired!
In order to prevent unauthorized access to the system, your request has been blocked. Click “Continue »” below to return to the previous page.
This token problem is a bug.
But installing LEDE/Openwrt is just the same as in the guide I posted.
Download Openwrt firmware from https://downloads.openwrt.org/snapshots/targets/ar71xx/generic/openwrt-ar71xx-generic-gl-ar300m-squashfs-sysupgrade.bin
Then flash using the existing UI, don’t reserve any settings.
I ended up booting libreCMC and i’m getting a bit farther in my project but for some reason I am unable to establish a wireguard handshake.
Just wait for our new UI then.
