I try to add Shadowsocks from the plugins (gl-ss and gl-ss-server) then i go to luci, select Services > Shadowsocks and after configure the settings then save it, i try to click connect on the admin panel VPN > SS Client > Connect, it’s nothing happen, the button just keep spinning, i view luci again and nothing is is running (Transparent Proxy, Socks5 Proxy), but when i reboot the router, after i sign-in again, the VPN SS Client is running, check the luci and (Transparent Proxy, Socks5 Proxy) is running, go back to Admin panel select the stop button and it stop instantly, try again and the same thing happen again, i have to reboot the router to make it show VPN (shadowsocks) is on running. then i try to activate it via Putty and not from the admin panel, in putty it’s active, but nothing in Luci, reboot the router and The VPN is on.
Anybody have the same problem?
here some screenshot
Here some system log when i try to run it from putty:
Fri Feb 12 18:16:37 2021 authpriv.info dropbear[1657]: Child connection from 192.168.88.222:57527
Fri Feb 12 18:16:47 2021 authpriv.notice dropbear[1657]: Password auth succeeded for ‘root’ from 192.168.88.222:57527
Fri Feb 12 18:17:47 2021 daemon.info ss-redir[3645]: initializing ciphers… chacha20-ietf-poly1305
Fri Feb 12 18:17:47 2021 daemon.info ss-redir[3645]: listening at 0.0.0.0:1234
Fri Feb 12 18:17:47 2021 daemon.info ss-redir[3645]: tcp port reuse enabled
Fri Feb 12 18:17:47 2021 daemon.info ss-redir[3645]: running from root user
Fri Feb 12 18:17:47 2021 daemon.err ss-redir[3645]: plugin service exit unexpectedly
Fri Feb 12 18:17:48 2021 daemon.info ss-local[3706]: initializing ciphers… chacha20-ietf-poly1305
Fri Feb 12 18:17:48 2021 daemon.info ss-local[3706]: listening at 0.0.0.0:1080
Fri Feb 12 18:17:48 2021 daemon.info ss-local[3706]: tcp port reuse enabled
Fri Feb 12 18:17:48 2021 daemon.info ss-local[3706]: udprelay enabled
Fri Feb 12 18:17:48 2021 daemon.info ss-local[3706]: udp port reuse enabled
Fri Feb 12 18:17:48 2021 daemon.info ss-local[3706]: running from root user
Fri Feb 12 18:17:48 2021 daemon.err ss-local[3706]: plugin service exit unexpectedly
And i use the latest firmware 3.105
I know it’s been too long but Problem solved in case anybody have the same issue, what i did is re-install the plugins software
-gl-ss 3.0.12-1
-luci-app-shadowsocks 1.8.2-1
-luci-app-shadowsocks-without ipset 1.8.2-1
-luci-app-shadowsocks-libev git-21.044.30835-34e0d65-1
-simple-obfs 0.0.5
restart the router, and configure the setting via luci, everything is up and running now, i can stop and start the vpn from putty or the web gui.
