If I have multiple OVPN profiles configured (e.g. home1194, home53, work1194, work53) and I have set the switch to turn OVPN on and off, which profile does it use? (First loaded? Most recently successful? Most recently attempted?..?)
Thanks.
Thanks.
A simple test should answer this for yourself - but as far as I am aware, it will use the last used one (the one selected in the VPN menu in the GL UI).
Glitch
You have to select one and apply. Then later you will use this one only.
