Every few days, the router will kick all clients off of WiFi and not allow any re-association. A power-cycle fixes it… Any idea what’s going on and what to look for? I use it to create a wireguard tunnel for all clients…
Does the LAN work? Could you send the system log and kernel log to here? You can find it in Advanced → Status → System Log / Kernel Log.
I’ll try to see if the LAN works and I can get that information the next time it happens…
