albsan
November 26, 2017, 1:24pm
Hi guys,
I’ve issue with the latest firmware for the ar300M ( 2.263):
“Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/2.263/packages/base/Packages.gz .
wget: server returned error: HTTP/1.1 404 Not Found”
I’ve checked and there aren’t folder on the repository for this version.
what’s happen?
alzhao
November 27, 2017, 12:00pm
2
Please try v2.264 GL.iNet download center
V2.263 do not have software repo.
glitch
February 13, 2018, 1:36am
3
Sorry to dig up an old thread but I have the same problem on 2.27.
Where can we find the repos?
In particular, I want to install Coova Chilli which I believe is included ion the repo…if only I could find it!
alzhao
February 13, 2018, 10:30am
4
V2.27 should have all the repo, no?
glitch
February 13, 2018, 1:59pm
5
I couldn;t get any packages. I tried adding this path (they have Coova):
Index of /snapshots/trunk/ar71xx/generic/packages/packages/ .
I get this error when trying to update package list in Luci:
Collected errors:
alzhao
February 13, 2018, 2:51pm
6
This is v2.27?
Is this the because you reserved the old settings ?
glitch
February 13, 2018, 4:00pm
7
Yes, that’ll probably be it! Will re-flash and report back
alzhao
February 13, 2018, 5:07pm
8
You can just use “revert to factory status” or press and hold the reset button for 10 seconds.
glitch
February 13, 2018, 10:22pm
9
Clean install of 2,27 done and all errors fixed.
Thanks,
G
