Since the last firmware update im experiencing openvpn problems.
On the glinet openvpn page where you can select which server to connect too. I select a different server and apply but it doesnt actually change. The server connecting text no longer appears and instead i get “Please wait”
Also the amount of disconnects has risen. Has anyone got a keepalived or a reconnect script to work?
I have tried factory reset and fresh vpn files but result is the same.
If you disable the switch (setting it to be No Function in the webui) you will have to reboot to clear up the duplicate openvpn processes that cause problems.
Since disabling the switch I have not had any issues. It reconnects if needed by itself - as it should.
I found these entries in system log. No idea if they are the problem or not.
12:49:04 2018 daemon.warn openvpn[21692]: WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
12:49:05 2018 daemon.warn openvpn[21692]: WARNING: ‘link-mtu’ is used inconsistently, local=‘link-mtu 1558’, remote=‘link-mtu 1542’
12:49:05 2018 daemon.warn openvpn[21692]: WARNING: ‘cipher’ is used inconsistently, local=‘cipher AES-128-CBC’, remote=‘cipher BF-CBC’
12:49:05 2018 daemon.notice openvpn[21692]: [84122158241287d90752bc38970e4aea] Peer Connection Initiated with AF_INET:1198
12:49:11 2018 daemon.notice netifd: Interface ‘VPN_client’ is enabled
12:49:11 2018 local1.info Keepalived_vrrp[2155]: Netlink: filter function error
