I tried getting this to work and I cannot for the life of me figure it out. I get the device connected and I am able to navigate the web. I switch the switch back to left and right(I might add the documenation page for connecting tor doesn’t show which is left or right very easily). Regardless I have put in both positions and it will not connect. I am able to connect just fine with TOR browser so not sure what the issue might be.
I have also went into system and serivce and stop/started tor and still doesn’t connect. I have tried 1 second hold of the button and that doesn’t work either. Please help.
Can you also please clarify which is right and left is it when its facing you and you are looking at it? Right now I have the switch flipped towards the Reset button.
I have disabled and renabled it. I have stopped and started it. I have tried everything I can to get it to work. I don’t believe it is disabled anymore.
I am connected on the LAN interface via a wired connection. Will it work that way?
I had read some old documentation that there should be a tor wwan but I don’t see the SSID broadcasting out.
Keep in mind that I am connecting to the internet in repearter mode basically. The AR300M is connected on a wifi network and then I am connected to it right now via LAN interface.
If not there try enable manually. /etc/init.d/tor restart
The firmware has a daemon which checks tor status so Tor should always be started.
Maybe you can reset your firmware to clear all settings then start over. Just to make sure you flashed the correct firmware without reserving old settings.
Sorry I fell asleep and when I reset this to factory it wont come back up now. I get an IP from the device via DHCP but I can no longer hit the web interface. Is there a way to unbrick this router now?
It is now booting with 3 lights on 2 green and 1 red.
I just went to bed and let it sit I can finally login to the web interface but it still the Tor firmware. How do I make sure I am running the right firmware for my current device. What commands can I run from the command line for you to review. I have a feeling I may have the wrong firmware.
Also TOR now shows 15% and has been stuck there for a while.
