I’ve attached a generic logitech webcam to the AR300M and can see it using the browser (192.168.8.1/stream or 192.168.8.1:8083) but it either needs the initial login, or it needs the login, PLUS a username and password that I set for the actual camera function. I’d like to be able to access the camera from a web browser, ideally external access (via port forwarding I guess), and a username / password - but I’m stuck at the first step. I can’t even get a browser to get a picture from the camera without having another tab on the same browser windows connected and logged into the router using “root” access.
If this can’t be done, then perhaps if I can access the cam using some generic software then that might help, but either way, without some way of using the picture from the webcam, this feels like more of a novelty feature than something with much real-world use.
I’ve read another article / post here concerning mjpg streamer, but I loaded that up and didn’t have much luck. If anyone could help then I’d be very grateful.
Thanks
Tarique
