The repository /openwrt/ar71xx_nand/2.264/ for my AR300M does not contain any adblock package. Why?
The repositoy /openwrt/ramips/2.264/ for my MT300A does contain adblock packages. Why?
I’ve check the two adblock package files adblock and luci-app-adblock. Both packages install shell scripts and HTML files, no binary files: The program “file” gives the following output:
file $(opkg files adblock | grep -v ^Package)
/usr/bin/adblock-helper.sh: POSIX shell script, ASCII text executable
/etc/hotplug.d/iface/90-adblock: POSIX shell script, ASCII text executable
/www/adblock/index.html: HTML document, ASCII text
/etc/adblock/adblock.conf.default: ASCII text
/etc/config/adblock: ASCII text
/etc/adblock/adblock.whitelist: empty
/usr/bin/adblock-update.sh: POSIX shell script, ASCII text executable
/etc/adblock/adblock.blacklist: ASCII text
/etc/init.d/adblock: POSIX shell script, ASCII text executable
file $(opkg files luci-app-adblock | grep -v ^Package)
/usr/lib/lua/luci/controller/adblock.lua: ASCII text
/usr/lib/lua/luci/model/cbi/adblock.lua: HTML document, ASCII text
If I manually transfer the package files adblock and luci-app-adblock from the MT300A to the AR300M and then install them with “opkg install ”, would this procedure do any harm to the AR300M?
Barney
