I have: AR 300M and Kuma USB Wifi Antena - Amazon.co.uk
I would like to use AR300M to use for local WiFi in my campervan which gets WiFi trough external USB antenna (KUMA) to connect to WiFi in my house.
If I am correct that means repeater mode. I go in settings to set up repeater - scan - it finds the network (it uses USB antenna for that for sure, otherwise it doesn’t find anything) but when I tpe password and click JOIN it doesn’t do anything.
UPDATE: Even if I try to do a repeater within GL UI without USB antenna it doesn’t join any WiFi network. Signal is full. But after clicking Join - nothing happens.
Than I went into advanced Luci.
I read a lot of stuff online, but can’t get it to work. It recognizes the USB antenna, but it doesn’t put it through my local WiFi here in a campervan. I’m attaching some screenshots:
