I bought this router to be able to connect to a wireless network with WPA2-Enterprise in repeater mode. I realized it work with some WPA2-Enterprise but I can`t find how to connect with EAP-PWD. I found the others modes but those are not accepted by this network. Is there any way to install a package in Luci that allows EAP-PWD to connect in repeater mode, or is it possible to implement this in the firmware? I tried with wpa_supplicant but I got a message that eap=PWD is not recognized, that makes me think that wpa_supplicant accept the other modes like EAP-TLS and other but not EAP-PWD-
Any ideas?
I think you MAY have to replace wpa-supplicant with wpad. Helped someone with eduroam at one time and sounds similar. Hopefully this points you in the right direction and some Googling might help! ![]()
I tried that also and it doesn`t have EAP-PWD
It doesn’t support EAP-PWD, it only support EAP-MD5, EAP-TLS, EAP-MSCHAPV2, EAP-GTC and EAP-TTLS.
