Using the router as wisp, when i lose my upstream WiFi connection it doesn’t reconnect after it returns. Here’s a log:
Tue Nov 20 18:43:15 2018 daemon.notice netifd: Network device ‘wlan0’ link is down
Tue Nov 20 18:43:15 2018 kern.info kernel: [21249.470787] br-lan: port 2(wlan0) entered disabled state
Tue Nov 20 18:43:15 2018 kern.info kernel: [21249.478640] wlan-sta: deauthenticating from a4:56:cc:40:6d:de by local choice (Reason: 3=DEAUTH_LEAVING)
Tue Nov 20 18:43:15 2018 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Tue Nov 20 18:43:15 2018 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Tue Nov 20 18:43:17 2018 kern.info kernel: [21251.409936] br-lan: port 2(wlan0) entered blocking state
Tue Nov 20 18:43:17 2018 kern.info kernel: [21251.415506] br-lan: port 2(wlan0) entered forwarding state
Tue Nov 20 18:43:17 2018 daemon.notice netifd: wwan (8292): udhcpc: received SIGTERM
Tue Nov 20 18:43:17 2018 daemon.notice netifd: Network device ‘wlan0’ link is up
Tue Nov 20 18:43:17 2018 daemon.notice netifd: Network device ‘wlan0’ link is down
Tue Nov 20 18:43:18 2018 user.info : [ 477] gl-health>> Scan and fixing the problems
Tue Nov 20 18:43:18 2018 daemon.notice netifd: Interface ‘wwan’ is disabled
Tue Nov 20 18:43:18 2018 kern.info kernel: [21252.434813] br-lan: port 2(wlan0) entered disabled state
Tue Nov 20 18:43:19 2018 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Tue Nov 20 18:43:19 2018 daemon.notice hostapd: wlan0: AP-DISABLED
Tue Nov 20 18:43:19 2018 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Tue Nov 20 18:43:19 2018 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Tue Nov 20 18:43:19 2018 kern.info kernel: [21252.760617] device wlan0 left promiscuous mode
Tue Nov 20 18:43:19 2018 kern.info kernel: [21252.765544] br-lan: port 2(wlan0) entered disabled state
Tue Nov 20 18:43:21 2018 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Tue Nov 20 18:43:21 2018 user.notice glfw: Reloading firewall due to ifdown of wwan ()
Tue Nov 20 18:43:22 2018 kern.info kernel: [21256.492896] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Tue Nov 20 18:43:22 2018 kern.info kernel: [21256.503620] br-lan: port 2(wlan0) entered blocking state
Tue Nov 20 18:43:22 2018 kern.info kernel: [21256.509198] br-lan: port 2(wlan0) entered disabled state
Tue Nov 20 18:43:22 2018 kern.info kernel: [21256.515202] device wlan0 entered promiscuous mode
Tue Nov 20 18:43:22 2018 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Tue Nov 20 18:43:23 2018 daemon.err hostapd: Using interface wlan0 with hwaddr e4:95:6e:43:bc:69 and ssid “Exile”
Tue Nov 20 18:43:23 2018 kern.info kernel: [21257.267820] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Tue Nov 20 18:43:23 2018 kern.info kernel: [21257.274856] br-lan: port 2(wlan0) entered blocking state
Tue Nov 20 18:43:23 2018 kern.info kernel: [21257.280354] br-lan: port 2(wlan0) entered forwarding state
Tue Nov 20 18:43:23 2018 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Tue Nov 20 18:43:23 2018 daemon.notice hostapd: wlan0: AP-ENABLED
Tue Nov 20 18:43:23 2018 daemon.notice netifd: Network device ‘wlan0’ link is up
Tue Nov 20 18:43:32 2018 user.info : [ 2708] gl-wifi-core>> Add (Powell) to BlackList.
Tue Nov 20 18:50:09 2018 daemon.info hostapd: wlan0: STA 64:bc:0c:42:a2:4e IEEE 802.11: authenticated
Tue Nov 20 18:50:09 2018 daemon.info hostapd: wlan0: STA 64:bc:0c:42:a2:4e IEEE 802.11: associated (aid 1)
Tue Nov 20 18:50:09 2018 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 64:bc:0c:42:a2:4e
Tue Nov 20 18:50:09 2018 daemon.info hostapd: wlan0: STA 64:bc:0c:42:a2:4e RADIUS: starting accounting session F8BA29F6CD188C9D
Tue Nov 20 18:50:09 2018 daemon.info hostapd: wlan0: STA 64:bc:0c:42:a2:4e WPA: pairwise key handshake completed (RSN)
Tue Nov 20 18:50:12 2018 daemon.info dnsmasq-dhcp[3708]: DHCPDISCOVER(br-lan) 64:bc:0c:42:a2:4e
Tue Nov 20 18:50:12 2018 daemon.info dnsmasq-dhcp[3708]: DHCPOFFER(br-lan) 192.168.8.206 64:bc:0c:42:a2:4e
Tue Nov 20 18:50:12 2018 daemon.info dnsmasq-dhcp[3708]: DHCPREQUEST(br-lan) 192.168.8.206 64:bc:0c:42:a2:4e
Tue Nov 20 18:50:12 2018 daemon.info dnsmasq-dhcp[3708]: DHCPACK(br-lan) 192.168.8.206 64:bc:0c:42:a2:4e
Tue Nov 20 18:50:13 2018 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 64:bc:0c:42:a2:4e
Tue Nov 20 18:51:34 2018 daemon.info dnsmasq-dhcp[3708]: DHCPREQUEST(br-lan) 192.168.8.103 00:04:4b:57:7e:6b
Tue Nov 20 18:51:34 2018 daemon.info dnsmasq-dhcp[3708]: DHCPACK(br-lan) 192.168.8.103 00:04:4b:57:7e:6b android-4fe2da797d098a85
Tue Nov 20 18:53:27 2018 user.info : [ 146] gl-sdk>> (HTML) new session init…
Tue Nov 20 18:53:35 2018 user.info : [ 387] gl-sdk>> session delete … Token invalid!
Tue Nov 20 18:53:37 2018 user.info : [ 172]: gl-sdk>> (FCGI) new session init…
Tue Nov 20 18:54:32 2018 user.info : [ 562] gl-sdk>> bIsSaved=1, ssid=Powell, encryption=psk2, bssid=A4:56:CC:40:6D:DE, wds=0, device=radio0, identity=, channel=36
Tue Nov 20 18:54:32 2018 user.info : [ 118] gl-health>> health_stop
Tue Nov 20 18:54:32 2018 user.info : [ 2591] gl-wifi-core>> bIsStaEnabled=1
Tue Nov 20 18:54:32 2018 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Tue Nov 20 18:54:32 2018 daemon.notice hostapd: wlan0: AP-DISABLED
Tue Nov 20 18:54:32 2018 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Tue Nov 20 18:54:32 2018 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Tue Nov 20 18:54:32 2018 kern.info kernel: [21926.125444] device wlan0 left promiscuous mode
Tue Nov 20 18:54:32 2018 kern.info kernel: [21926.130268] br-lan: port 2(wlan0) entered disabled state
Tue Nov 20 18:54:32 2018 daemon.notice netifd: Network device ‘wlan0’ link is down
Tue Nov 20 18:54:34 2018 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Tue Nov 20 18:54:35 2018 kern.info kernel: [21929.352685] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Tue Nov 20 18:54:35 2018 kern.info kernel: [21929.370217] br-lan: port 2(wlan0) entered blocking state
Tue Nov 20 18:54:35 2018 kern.info kernel: [21929.375941] br-lan: port 2(wlan0) entered disabled state
Tue Nov 20 18:54:35 2018 kern.info kernel: [21929.381868] device wlan0 entered promiscuous mode
Tue Nov 20 18:54:35 2018 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Tue Nov 20 18:54:36 2018 daemon.err hostapd: Using interface wlan0 with hwaddr e6:95:6e:43:bc:69 and ssid “Exile”
Tue Nov 20 18:54:36 2018 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Tue Nov 20 18:54:36 2018 daemon.notice hostapd: wlan0: AP-ENABLED
Tue Nov 20 18:54:36 2018 kern.info kernel: [21930.260429] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
Tue Nov 20 18:54:36 2018 daemon.notice netifd: radio0 (30763): Successfully initialized wpa_supplicant
Tue Nov 20 18:54:37 2018 daemon.notice netifd: Interface ‘wwan’ is enabled
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.211456] wlan-sta: authenticate with a4:56:cc:40:6d:de
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.267927] wlan-sta: send auth to a4:56:cc:40:6d:de (try 1/3)
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.275035] wlan-sta: authenticated
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.302508] wlan-sta: associate with a4:56:cc:40:6d:de (try 1/3)
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.334212] wlan-sta: RX AssocResp from a4:56:cc:40:6d:de (capab=0x1511 status=0 aid=2)
Tue Nov 20 18:54:38 2018 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Tue Nov 20 18:54:38 2018 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Tue Nov 20 18:54:38 2018 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.371249] wlan-sta: associated
Tue Nov 20 18:54:38 2018 kern.info kernel: [21932.404984] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Tue Nov 20 18:54:38 2018 kern.debug kernel: [21932.413486] wlan-sta: Limiting TX power to 127 (127 - 0) dBm as advertised by a4:56:cc:40:6d:de
Tue Nov 20 18:54:39 2018 daemon.notice netifd: wwan (31029): udhcpc: started, v1.28.3
Tue Nov 20 18:54:39 2018 daemon.notice netifd: wwan (31029): udhcpc: sending discover
Tue Nov 20 18:54:39 2018 kern.info kernel: [21933.353012] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Tue Nov 20 18:54:39 2018 kern.info kernel: [21933.359964] br-lan: port 2(wlan0) entered blocking state
Tue Nov 20 18:54:39 2018 kern.info kernel: [21933.365529] br-lan: port 2(wlan0) entered forwarding state
Tue Nov 20 18:54:39 2018 daemon.notice netifd: Network device ‘wlan0’ link is up
Tue Nov 20 18:54:41 2018 user.info : [ 568] gl-sdk>> wifi_join return=0
Tue Nov 20 18:54:42 2018 daemon.notice netifd: wwan (31029): udhcpc: sending discover
Tue Nov 20 18:54:42 2018 daemon.notice netifd: wwan (31029): udhcpc: sending select for 10.0.0.9
Tue Nov 20 18:54:42 2018 daemon.notice netifd: wwan (31029): udhcpc: lease of 10.0.0.9 obtained, lease time 2147483
Tue Nov 20 18:54:42 2018 daemon.notice netifd: Interface ‘wwan’ is now up
Tue Nov 20 18:54:47 2018 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Tue Nov 20 18:54:57 2018 user.info : [ 146] gl-sdk>> (HTML) new session init…
Tue Nov 20 18:55:01 2018 user.notice glfw: Reloading firewall due to ifup of wwan (wlan-sta)
Tue Nov 20 18:55:08 2018 user.info : [ 387] gl-sdk>> session delete … Token invalid!
Please note i logged into the gl interface to reconnect manually
