I just got my AR750 and I am having an extremely hard time getting it to stay connected to my computer. it boots on and then about every 5 mins or so the 2g light flashes and I loose connection to my computer then it comes back on and trys to connect to the internet again but continues the cycle. I am trying to use it in repeater mode on open hotel wifi. How can i fix this?
Seems to me it’s roaming between the (probably many) available APs that your hotel has available to connect to- maybe because you’re far enough away from them all it’s having a hard time keeping a good signal. Can you try moving the AR750 closer to the hallway (or maybe a window) and see if it makes any difference?
Due to the way the repeater (WISP) mode works, if the WAN WiFi roams to another AP, your computer may temporarily lose the signal until the WAN WiFi gets successfully associated (I think that’s right, @alzhao? Please correct me if I’m wrong.)
It doesn’t matter where the router is, i can barely keep it connected long enough to turn the 5g on and when i do it doesn’t show up on my wireless networks
