hi
What’s its use button mode switch ?
it must be left or right ?
thanks for your response.
If you haven’t set it up yet, it’s a “No-Op” (does nothing).
It can be used to switch between modes, or VPN on/off if you set it up in the GUI.
thanks you i have used this button for enable or disable openvpn.
