First, pardon my technical-terminology ignorance. I am not quite sure what the right terminology is regarding what my actual goal is. However, I would like to use the AR750 with VPN enable between my cable modem and my home wifi router.
Cable Modem >> AR750 (w/ openVPN or Wiregaurd enabled) >> Wifi Router Mesh System
End goal is to have ALL home devices connected to my home wifi, running through the VPN certificate I install on the AR750.
Is this possible? I have not had luck looking up guides or googling…
TIA
