Topic says everything, just tried tethering and on web interface I see only No phone device connected.
logread
Thu Apr 26 16:29:20 2018 kern.info kernel: [22347.863721] usb 1-1.2: USB disconnect, device number 6
Thu Apr 26 16:29:20 2018 kern.info kernel: [22348.124136] usb 1-1.2: new high-speed USB device number 7 using ehci-platform
I think with the current release of OpenWRT, esp since the merge between LEDE Project and OpenWRT as of 1/2018, some minor, non obvious, changes occurred with the way the USB device was presented within the system log and the clear omission of the interface identifier. In my specific case, I’m using iOS 11.3.1 on an iPhone 6.
Traditionally the device has been named ‘usb0’, however with my GL-AR300M w/ the 128MB of NAND, I wasn’t able to get this work.
I manually created the interface, no joy
I verified the libraries were installed and even tried reinstalling them, no joy
I connected the unit to an internet connection and auto-updated the firmware from 2.264 to 2.27, no joy
I finally found a reference regarding OpenWRT. It showed that I had to manually edit /etc/config/network (I used vi) to add a new interface. I added the following lines:
config interface ‘TetheringWAN’
option proto 'dhcp'
option ifname 'eth2'
Basically eth2 was mentioned as the interface instead of usb0 in the OpenWRT reference and this solved my issues. For whatever reason the OpenWRT/LEDE team in the most recent releases of OpenWRT don’t use usb0 anymore for network interfaces.
If you are a little more comfortable w/ linux, you can just list the interfaces by using ‘ifconfig’.
The point is that the OS recognizes the device as being present, but it doesn’t mention what the interface is:
– It’s an OS issue. You’ll note that @MucFlyer doesn’t add anything else besides those two lines because in the dmesg output, there is nothing else. The OS doesn’t automatically create the interface properly in 2.264 or 2.27.
However, my iPhone tethers with no problem in Apple Mac OS X
@alzhao I tried that. Didn’t work. Manually creating the interface was the only way. I can imagine that if you modify the firmware to add the interface already, then there would be no problem.
Why not just pre-make the interface for ‘usb0’ and for ‘eth2’ in the next release?
Thanks for the info @kalieaire. I have tried your suggestions (using eth1, eth2, usb0, usb1, usb2) and still can’t get it to tether to my Nokia 8 running Android 8.1. As stated previously, the phone tethers fine to Windows 7.
Log message when the phone is connected below, but the same issue as @MucFlyer with his Oneplus 5T.
[ 1140.507976] usb 1-1: USB disconnect, device number 6
[ 1141.177410] usb 1-1: new high-speed USB device number 7 using ehci-platform
I’ve done a bit more digging and it would seem that the RNDIS driver isn’t being loaded for the device. From /sys/kernel/debug/usb/devices I’ve got the following:
I think where it states Driver=(none) it should be showing Driver=rndis_host. I’ve read about USB mode switching, and am pretty sure the mode is correct as the vendor and product IDs listed here are the same as when it successfully tethers to Windows 7.
So, any idea why the RNDIS driver isn’t loading for the device, and how I can attempt to resolve this?
