Hi there. Have setup my AR750 with tethering to a Franklin R910 mifi modem, seeing it properly as usb0. I have two SSIDs setup, one 5G, the other 2.4G.
Is there a quick / easy way to log/view data usage over time, either by SSID, or by MAC address? I have dug through all the menus, including the advanced settings menus, but havent found anything self-evident. I’m not very advanced in my technical skills (like, I can’t program my own commands).
I have checked out YAMon webpage, but it seems a bit daunting, and it requires me to have a USB stick in the usb port, which I cant do right now (tethering).
I would consider upgrading the firmware to 3rd party with native support for usage logs, but would need to make sure I dont sacrifice tethering capability or brick my box.
Any ideas? Looking to monitor data usage to break down who’s using how many Gigs per month. Thanks in advance!!
