How to I access the Uboot on the AR750S. I somehow managed to brick it and I cant get back to the interface. I tried the usual uboot process of holding reset for 5 light flashes after power up but router is not reacheable at 192.168.1.1.
Did you set the ethernet adapter to 192.168.1.2?
Did you follow this tutorial step by step? Debrick via Uboot - GL.iNet Docs
Followed the instructions but the uboot page will not come up to send the firmware. I’ve done this many times before. Maybe faulty box.
Did you only attach one cable? It can’t work if you attach two or more cables. What’s your OS? It had a bug on Ubuntu before, but had fixed it.
