AR750S: Connecticut to clients from tethered network
I’m using my AR750S to extend my home network in a far corner of my house where I can’t run a cable drop to. Is there a way to see/connect to the clients from the tethered network ?
Tethering network? Do you mean your main network?
You can use extender mode: go to more settings->network mode->extender
Pls note, in extender mode, if you want to revert back to router mode, press and hold reset for 4 seconds.
Ah yes. Perfect thanks you
