Hi, I am the proud new owner of a Slate and rather like it so far.
However, I have not found a way to enable dynamic dns via the admin panel/LuCI and am a little surprised that such a basic function is not available. It is quite important for my production environment here and I want to avoid setting up a DDNS service behind the router if at all possible. Are there any plans to implement a DDNS solution?
On a different note, and less relevant (and therefore not starting a new thread): is there a reason why no adblock packages are available for the AR750s? Am I able to install them manually or might this break the current v3 firmware?
Thank you!
