I am living in an accommodation with open wifi with portal and I been using it sometime. Now, I been trying to play stadia on my mac, It works fine, but I can’t seem to connect my stadia controller, so I decided to buy a travel router because I’ve read many discussion about the problem and it seems to be common and there solution is to buy a travel router. And so I did, I bought the GL-inet AR750 slate, I connected it to the wifi and it works for a bit and it gave me a stable speed. But when I connected my Stadia Controller, it works for a minute and then the router is disconnected from the WIFI.
If anyone has a solution to my problem, please share it with me. It will be very much appreciated. Thanks
Can you get the log when you have this problem?
Ssh to the router and use logread command to get the log
sorry, unfortunately, I can’t. I mean, I dont know how to do it.
Follow the guide here:
Then in the terminal just type logread and press enter, copy the log here.
Thu Apr 15 04:08:45 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 04:16:16 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 04:16:16 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 04:22:36 2021 daemon.info dnsmasq-dhcp[564]: DHCPREQUEST(br-lan) 192.168.8.211 c4:91:0c:af:31:ee
Thu Apr 15 04:22:36 2021 daemon.info dnsmasq-dhcp[564]: DHCPACK(br-lan) 192.168.8.211 c4:91:0c:af:31:ee Thomass-MBP
Thu Apr 15 04:23:46 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 04:23:46 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 04:31:16 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 04:31:16 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 04:32:13 2021 authpriv.info dropbear[29217]: Child connection from 192.168.8.211:51973
Thu Apr 15 04:37:13 2021 authpriv.info dropbear[29217]: Exit before auth (user ‘root’, 0 fails): Timeout before auth
Thu Apr 15 04:38:46 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 04:38:46 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 04:46:16 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 04:46:16 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 04:53:46 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 04:53:46 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:01:16 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:01:16 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:08:46 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:08:46 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:16:17 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:16:17 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:23:47 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:23:47 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:31:17 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:31:17 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:38:47 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:38:47 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:46:18 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:46:18 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 05:53:48 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 05:53:48 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 06:00:34 2021 authpriv.info dropbear[567]: Child connection from 192.168.8.211:52336
Thu Apr 15 06:00:46 2021 authpriv.notice dropbear[567]: Password auth succeeded for ‘root’ from 192.168.8.211:52336
Thu Apr 15 06:01:18 2021 daemon.notice netifd: wwan (5883): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 06:01:18 2021 daemon.notice netifd: wwan (5883): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 06:01:35 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c IEEE 802.11: authenticated
Thu Apr 15 06:01:35 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c IEEE 802.11: associated (aid 1)
Thu Apr 15 06:01:35 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED f0:ef:86:39:8b:7c
Thu Apr 15 06:01:35 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c RADIUS: starting accounting session 8B81D4933500C419
Thu Apr 15 06:01:35 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c WPA: pairwise key handshake completed (RSN)
Thu Apr 15 06:01:35 2021 daemon.info dnsmasq-dhcp[564]: DHCPREQUEST(br-lan) 192.168.8.129 f0:ef:86:39:8b:7c
Thu Apr 15 06:01:35 2021 daemon.info dnsmasq-dhcp[564]: DHCPACK(br-lan) 192.168.8.129 f0:ef:86:39:8b:7c Stadia-4b0c
Thu Apr 15 06:02:55 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Thu Apr 15 06:02:55 2021 kern.info kernel: [110745.273342] br-lan: port 3(wlan1) entered disabled state
Thu Apr 15 06:02:55 2021 kern.info kernel: [110745.281882] wlan-sta: deauthenticating from 20:b3:99:bc:02:48 by local choice (Reason: 3=DEAUTH_LEAVING)
Thu Apr 15 06:02:55 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Thu Apr 15 06:02:55 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Thu Apr 15 06:02:55 2021 daemon.notice netifd: wwan (5883): udhcpc: received SIGTERM
Thu Apr 15 06:02:55 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Thu Apr 15 06:02:55 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Thu Apr 15 06:02:55 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Thu Apr 15 06:02:55 2021 daemon.warn dnsmasq[564]: no servers found in /tmp/resolv.conf.auto, will retry
Thu Apr 15 06:02:55 2021 daemon.notice wpa_supplicant[5777]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=20:b3:99:bc:02:48 reason=3 locally_generated=1
Thu Apr 15 06:02:56 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 15 06:02:57 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 15 06:03:00 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 15 06:03:00 2021 kern.info kernel: [110750.127899] br-lan: port 3(wlan1) entered blocking state
Thu Apr 15 06:03:00 2021 kern.info kernel: [110750.133539] br-lan: port 3(wlan1) entered forwarding state
Thu Apr 15 06:03:00 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Thu Apr 15 06:03:41 2021 user.info : saved ssid ignore: NHS WI-FI 0
Thu Apr 15 06:03:41 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=NHS WI-FI, encryption=none, bssid=20:B3:99:BC:02:48, wds=0, device=radio1, identity=, channel=6
Thu Apr 15 06:03:41 2021 user.info : [ 3031] gl-wifi-core>> bIsStaEnabled=1
Thu Apr 15 06:03:47 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED f0:ef:86:39:8b:7c
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 26:8f:91:41:9b:d9
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 56:6a:a7:bd:bc:26
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: wlan1: AP-DISABLED
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Thu Apr 15 06:03:47 2021 daemon.err wpa_supplicant[5777]: Failed to stop hostapd AP interfaces
Thu Apr 15 06:03:47 2021 daemon.notice wpa_supplicant[5777]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Thu Apr 15 06:03:47 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Thu Apr 15 06:03:47 2021 kern.info kernel: [110797.310176] device wlan1 left promiscuous mode
Thu Apr 15 06:03:47 2021 kern.info kernel: [110797.314999] br-lan: port 3(wlan1) entered disabled state
Thu Apr 15 06:03:47 2021 daemon.notice wpa_supplicant[5777]: wlan-sta: CTRL-EVENT-TERMINATING
Thu Apr 15 06:03:47 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Thu Apr 15 06:03:49 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Thu Apr 15 06:03:49 2021 kern.info kernel: [110799.428282] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Thu Apr 15 06:03:49 2021 user.notice sysctl: net.ipv6.conf.wlan1.accept_ra = 2
Thu Apr 15 06:03:49 2021 kern.info kernel: [110799.553040] br-lan: port 3(wlan1) entered blocking state
Thu Apr 15 06:03:49 2021 kern.info kernel: [110799.558682] br-lan: port 3(wlan1) entered disabled state
Thu Apr 15 06:03:49 2021 kern.info kernel: [110799.564591] device wlan1 entered promiscuous mode
Thu Apr 15 06:03:49 2021 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->HT_SCAN
Thu Apr 15 06:03:50 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 15 06:03:51 2021 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=6 sec=10 based on overlapping BSSes
Thu Apr 15 06:03:51 2021 daemon.err hostapd: Using interface wlan1 with hwaddr 94:83:c4:0d:96:72 and ssid “GL-AR750S-672”
Thu Apr 15 06:03:51 2021 kern.info kernel: [110801.021947] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Thu Apr 15 06:03:51 2021 kern.info kernel: [110801.028842] br-lan: port 3(wlan1) entered blocking state
Thu Apr 15 06:03:51 2021 kern.info kernel: [110801.034443] br-lan: port 3(wlan1) entered forwarding state
Thu Apr 15 06:03:51 2021 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Thu Apr 15 06:03:51 2021 daemon.notice hostapd: wlan1: AP-ENABLED
Thu Apr 15 06:03:51 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Thu Apr 15 06:03:54 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 IEEE 802.11: authenticated
Thu Apr 15 06:03:54 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 IEEE 802.11: associated (aid 1)
Thu Apr 15 06:03:54 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 26:8f:91:41:9b:d9
Thu Apr 15 06:03:54 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 RADIUS: starting accounting session FDF18E226B0C41D4
Thu Apr 15 06:03:54 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 WPA: pairwise key handshake completed (RSN)
Thu Apr 15 06:03:56 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 IEEE 802.11: authenticated
Thu Apr 15 06:03:56 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 IEEE 802.11: associated (aid 2)
Thu Apr 15 06:03:56 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 56:6a:a7:bd:bc:26
Thu Apr 15 06:03:56 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 RADIUS: starting accounting session 15D29F91DF7E814E
Thu Apr 15 06:03:56 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 WPA: pairwise key handshake completed (RSN)
Thu Apr 15 06:03:56 2021 daemon.info dnsmasq-dhcp[564]: DHCPREQUEST(br-lan) 192.168.8.142 56:6a:a7:bd:bc:26
Thu Apr 15 06:03:56 2021 daemon.info dnsmasq-dhcp[564]: DHCPACK(br-lan) 192.168.8.142 56:6a:a7:bd:bc:26 Suzys-iPhone
Thu Apr 15 06:04:05 2021 user.info : [ 3031] gl-wifi-core>> bIsStaEnabled=1
Thu Apr 15 06:04:05 2021 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Thu Apr 15 06:04:05 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 56:6a:a7:bd:bc:26
Thu Apr 15 06:04:05 2021 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 26:8f:91:41:9b:d9
Thu Apr 15 06:04:05 2021 daemon.notice hostapd: wlan1: AP-DISABLED
Thu Apr 15 06:04:05 2021 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Thu Apr 15 06:04:05 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Thu Apr 15 06:04:05 2021 kern.info kernel: [110815.545227] device wlan1 left promiscuous mode
Thu Apr 15 06:04:05 2021 kern.info kernel: [110815.550092] br-lan: port 3(wlan1) entered disabled state
Thu Apr 15 06:04:05 2021 daemon.notice netifd: Network device ‘wlan1’ link is down
Thu Apr 15 06:04:06 2021 user.notice sysctl: net.ipv6.conf.wlan-sta.accept_ra = 2
Thu Apr 15 06:04:06 2021 user.notice sysctl: net.ipv6.conf.wlan-sta.accept_ra = 0
Thu Apr 15 06:04:07 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Thu Apr 15 06:04:07 2021 kern.info kernel: [110816.866540] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Thu Apr 15 06:04:07 2021 kern.info kernel: [110816.901216] br-lan: port 3(wlan1) entered blocking state
Thu Apr 15 06:04:07 2021 kern.info kernel: [110816.907016] br-lan: port 3(wlan1) entered disabled state
Thu Apr 15 06:04:07 2021 kern.info kernel: [110816.912979] device wlan1 entered promiscuous mode
Thu Apr 15 06:04:07 2021 daemon.err hostapd: Using interface wlan1 with hwaddr 96:83:c4:0d:96:72 and ssid “GL-AR750S-672”
Thu Apr 15 06:04:07 2021 user.notice sysctl: net.ipv6.conf.wlan1.accept_ra = 2
Thu Apr 15 06:04:07 2021 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Thu Apr 15 06:04:07 2021 daemon.notice hostapd: wlan1: AP-ENABLED
Thu Apr 15 06:04:08 2021 kern.info kernel: [110817.788901] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
Thu Apr 15 06:04:08 2021 daemon.notice wpa_supplicant[6566]: Successfully initialized wpa_supplicant
Thu Apr 15 06:04:08 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Thu Apr 15 06:04:08 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 15 06:04:09 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: SME: Trying to authenticate with 20:b3:99:bc:02:48 (SSID=‘NHS WI-FI’ freq=2437 MHz)
Thu Apr 15 06:04:09 2021 kern.info kernel: [110818.939735] wlan-sta: authenticate with 20:b3:99:bc:02:48
Thu Apr 15 06:04:09 2021 kern.info kernel: [110818.958257] wlan-sta: send auth to 20:b3:99:bc:02:48 (try 1/3)
Thu Apr 15 06:04:09 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: Trying to associate with 20:b3:99:bc:02:48 (SSID=‘NHS WI-FI’ freq=2437 MHz)
Thu Apr 15 06:04:09 2021 kern.info kernel: [110818.998435] wlan-sta: authenticated
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.008864] wlan-sta: associate with 20:b3:99:bc:02:48 (try 1/3)
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.138680] wlan-sta: associate with 20:b3:99:bc:02:48 (try 2/3)
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.155283] wlan-sta: RX AssocResp from 20:b3:99:bc:02:48 (capab=0xe01 status=0 aid=2)
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.164030] wlan-sta: associated
Thu Apr 15 06:04:09 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Thu Apr 15 06:04:09 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Thu Apr 15 06:04:09 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Thu Apr 15 06:04:09 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: Associated with 20:b3:99:bc:02:48
Thu Apr 15 06:04:09 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 20:b3:99:bc:02:48 completed [id=0 id_str=]
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.173179] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.334840] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.341923] br-lan: port 3(wlan1) entered blocking state
Thu Apr 15 06:04:09 2021 kern.info kernel: [110819.347504] br-lan: port 3(wlan1) entered forwarding state
Thu Apr 15 06:04:09 2021 daemon.notice netifd: Network device ‘wlan1’ link is up
Thu Apr 15 06:04:09 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Thu Apr 15 06:04:09 2021 daemon.notice netifd: wwan (6676): udhcpc: started, v1.30.1
Thu Apr 15 06:04:09 2021 daemon.notice netifd: wwan (6676): udhcpc: sending discover
Thu Apr 15 06:04:10 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=6
Thu Apr 15 06:04:10 2021 daemon.notice netifd: wwan (6676): udhcpc: sending select for 10.188.112.35
Thu Apr 15 06:04:10 2021 daemon.notice netifd: wwan (6676): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 06:04:10 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: reading /tmp/resolv.conf.auto
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using local addresses only for domain test
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using local addresses only for domain onion
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using local addresses only for domain localhost
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using local addresses only for domain invalid
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using local addresses only for domain bind
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using local addresses only for domain lan
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using nameserver 52.56.135.63#53
Thu Apr 15 06:04:10 2021 daemon.info dnsmasq[564]: using nameserver 52.56.160.19#53
Thu Apr 15 06:04:13 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 IEEE 802.11: authenticated
Thu Apr 15 06:04:13 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 IEEE 802.11: associated (aid 1)
Thu Apr 15 06:04:13 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 56:6a:a7:bd:bc:26
Thu Apr 15 06:04:13 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 RADIUS: starting accounting session 4EF3E1BAB02DF990
Thu Apr 15 06:04:13 2021 daemon.info hostapd: wlan1: STA 56:6a:a7:bd:bc:26 WPA: pairwise key handshake completed (RSN)
Thu Apr 15 06:04:15 2021 user.info mwan3rtmon[3097]: Detect rtchange event.
Thu Apr 15 06:04:16 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Thu Apr 15 06:04:16 2021 daemon.err dnsmasq[564]: failed to send packet: Operation not permitted
Thu Apr 15 06:04:20 2021 user.notice nat6: Firewall config=“cfg02dc81” zone=“lan” zone_masq6=“0”.
Thu Apr 15 06:04:20 2021 user.notice nat6: Firewall config=“cfg03dc81” zone=“wan” zone_masq6=“1”.
Thu Apr 15 06:04:20 2021 user.notice nat6: Found firewall zone_name=“wan” with zone_masq6=“1” zone_masq6_privacy=“1”.
Thu Apr 15 06:04:20 2021 user.notice nat6: Setting up masquerading nat6 for zone_name=“wan” with zone_masq6_privacy=“1”
Thu Apr 15 06:04:20 2021 user.notice nat6: Ensuring ip6tables chain=“zone_wan_postrouting” contains our MASQUERADE.
Thu Apr 15 06:04:20 2021 user.notice nat6: Ensuring ip6tables chain=“zone_wan_input” contains our permissive DNAT rule.
Thu Apr 15 06:04:20 2021 user.notice nat6: Ensuring ip6tables chain=“zone_wan_forward” contains our permissive DNAT rule.
Thu Apr 15 06:04:20 2021 user.notice nat6: Done setting up nat6 for zone=“wan” on devices:
Thu Apr 15 06:04:20 2021 user.notice nat6: Firewall config=“guestzone” zone=“guestzone” zone_masq6=“0”.
Thu Apr 15 06:04:31 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 IEEE 802.11: authenticated
Thu Apr 15 06:04:31 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 IEEE 802.11: associated (aid 2)
Thu Apr 15 06:04:31 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 26:8f:91:41:9b:d9
Thu Apr 15 06:04:31 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 RADIUS: starting accounting session B1B0C984F14834D4
Thu Apr 15 06:04:31 2021 daemon.info hostapd: wlan1: STA 26:8f:91:41:9b:d9 WPA: pairwise key handshake completed (RSN)
root@GL-AR750S:~#
Here’s another one:
Thu Apr 15 06:08:07 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:08 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:09 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:12 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:14 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:17 2021 authpriv.info dropbear[567]: Exit (root): Disconnect received
Thu Apr 15 06:08:18 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:22 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:24 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c IEEE 802.11: authenticated
Thu Apr 15 06:08:24 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c IEEE 802.11: associated (aid 3)
Thu Apr 15 06:08:24 2021 daemon.notice hostapd: wlan1: AP-STA-CONNECTED f0:ef:86:39:8b:7c
Thu Apr 15 06:08:24 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c RADIUS: starting accounting session 031E14EA7418C3D2
Thu Apr 15 06:08:24 2021 daemon.info hostapd: wlan1: STA f0:ef:86:39:8b:7c WPA: pairwise key handshake completed (RSN)
Thu Apr 15 06:08:24 2021 daemon.info dnsmasq-dhcp[564]: DHCPREQUEST(br-lan) 192.168.8.129 f0:ef:86:39:8b:7c
Thu Apr 15 06:08:24 2021 daemon.info dnsmasq-dhcp[564]: DHCPACK(br-lan) 192.168.8.129 f0:ef:86:39:8b:7c Stadia-4b0c
Thu Apr 15 06:08:29 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:33 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:08:36 2021 daemon.notice wpa_supplicant[6579]: wlan-sta: CTRL-EVENT-BEACON-LOSS
Thu Apr 15 06:11:41 2021 daemon.notice netifd: wwan (6676): udhcpc: sending renew to 10.188.112.1
Thu Apr 15 06:11:41 2021 daemon.notice netifd: wwan (6676): udhcpc: lease of 10.188.112.35 obtained, lease time 900
Thu Apr 15 06:12:16 2021 authpriv.info dropbear[20552]: Child connection from 192.168.8.211:52758
Thu Apr 15 06:12:30 2021 authpriv.warn dropbear[20552]: Bad password attempt for ‘root’ from 192.168.8.211:52758
Thu Apr 15 06:12:36 2021 authpriv.notice dropbear[20552]: Password auth succeeded for ‘root’ from 192.168.8.211:52758
root@GL-AR750S:~#
Seems a lot of disconnect. Dorm wifi is really difficult. In the first log I can see Stadia connected and wifi disconnected.
I have no clue. But are you using firmware 3.201? If not can you upgrade?
Also try a different power adapter to the router
