I am using the AR750S-Ext as a router plugged into my home network so I can hand out static IP address in a subnet. NO WIFI enabled. I have the AR750S-Ext (192.168.8.1) plugged into my home network (192.168.2.1) via the WAN and all the equipment is connected to the subnet via a switch.
I am getting half the throughput when I add the AR750S-Ext into the picture than when I just plug the ethernet cable coming directly from the home network into the switch (I had to change some IP adresses in order to complete the test).
I have no VPN or any other functionality enabled.
Is there something I am missing to improve the Slate’s throughput?
