Hi.
I am trying to establish a connection for the GL-AR750S-Ext with Verizon USB 551L router and getting no connection
Does anybody tested it before?
Hi.
Have you tested that the USB modem works on a PC/computer?
What colour is the LED status indicator on the GL-AR750S? Also, check that the kmod-usb-net-qmi-wwan has been installed.
I did test it with Windows with no issue after installing Novatel driver and using VZAccess Manager Software
I see 3 LED on GL-AR750S Power 2G and 5G, all are on.
kmod-usb-net-qmi-wwan is installed
Novatel USB551L (Verizon) is listed as a compatible modem with QMI. Auto Setup and Manual Setup procedures:
Check what is displayed in Manual Setup. Choose QMI and input the correct apn.
If not already done so, then try upgrading to the latest firmware version.
As you are using another modem I dont know exactly how it works. Generally Verizon network needs a process of operation to activate the service.
I can only give some method so that you can try.
First find the device list and see what devices are there, e.g. ttyUSB0, ttyUSB1 …
There is one interface used for data. Need to choose that device
Then set the APN to “VZWADMIN”, and Apply wait a while so that it dials.
Go to more settings, IPV6 and enable IPV6. choose modem_1_1_2 and apply.
Go back to modem settings, choose device cdc-wdm0 and use apn VZWINTERNET an apply.
Just tried to updated to latest version and it did not help
I’ve tried that
I was not able to find modem_1_1_2 in IPV6
however I enabled it and made step 3. still did not help
oh if you use qmi mode it should be wwan.
Sorry seems I was wrong.
wwan is for repeater.
Can you just enable ipv6, then edit the config directly /etc/config/network and modify the interface
config interface ‘wan6’
option proto ‘dhcpv6’
option ifname ‘@modem_1_1_2’
option disabled ‘0’
