Whenever my router loses power or I restart it it factory resets itself and I lose all settings and I start at 192.168.8.1/#welcome and have to create admin password … please help thanks!
I only met such cases for routers with 16M Nor flash. When someone intalled too many software packages and make the flash full, after reboot the system cannot be mounted and you need to init again.
I am not sure about your case about AR750s but this is what you can do:
- Log in the UI successfully.
- Go to more settings->revert firmware and do a firmware revert manually.
After the system reboot, pls check if you still have the problems.
If not, can you ssh to the router and do some checks using these command.
mount
logread
