Ar750s is this a new device?
There is a new firmware in downloads:
http://www.gl-inet.com/firmware/ar750s/release/lede-ar750s-3.0.img
Uploading it on ar750 brick up the router. God bless Uboot!
Yes, AR750S is our new device. You can try uboot to rescue your AR750
Thanks for reply!
Where can I see the characteristics of the device and when will it be available?
Ar750 today is the best for travel! I’m very pleased with the router. Thanks.
PS. No any troubles with de-brick.
They sent a patch to OpenWrt project to add support for the ar750s http://lists.infradead.org/pipermail/openwrt-devel/2018-May/012386.html
Specification:
  • SOC: QCA9563 (775MHz)
  • Flash: 16 MiB (W25Q128FVSG)
  • RAM: 128 MiB DDR2
  • Ethernet: 2x 1Gbps LAN + 1x 1Gbps WAN
  • Wireless: 2.4GHz (bgn) and 5GHz (ac)
  • USB: 1x USB 2.0 port
  • Button: 1x switch button, 1x reset button
  • LED: 3x LEDS (green)
Slightly faster CPU, ethernet ports are now gigabit. the rest is the same.
There is definitely new features not listed here.
Does it have connectors for external antennas on both bands? Or either?
Heh. Yeah, I tried it too :slight_smile:
Expansion of flash memory up to 32MB would be awesome…
How about 128MB Nand?
What’s the estimated time of arrival on the AR750S? Will it have uFL ports to add an external antenna?
It does has uFL and it has external antenna version.
Both internal antenna and external version has uFL connector for both 2.4G and 5G in 750s.
The external antenna version is modified case and antenna without touching the PCB.
