I have to configure this as a repeater and I don’t control the building wifi router. If I use default wireguard client to mullvad it gets blocked. What would I need to change on my little AR750S to use a different port?
Port 53 is used as DNS and is not recommended, but you can try port 443.
Replace 443 in /etc/lighttpd/conf.d/30-openssl.conf with a different port and then restart the router.
At the risk of exposing my ignorance but how do I go about getting access to the file system of the router? I’ve only ever accessed it through the phone app or web page UI.
Thanks. I should have known to RTFM!
