i tried to boot into recovery, but it does not seem to have network connection.
i attached a laptop with static ip 192.168.1.2 to external port
i then attached a serial console cable this is the output:
U-Boot 1.1.4-ga35cd45d-dirty (Jun 22 2018 - 12:48:24)
ar750s - Dragonfly 1.0DRAM:
sri
ath_ddr_initial_config(278): (ddr2 init)
ath_sys_frequency: cpu 775 ddr 650 ahb 258
Tap values = (0xe, 0xe, 0xe, 0xe)
128 MB
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16MB, sector count = 256
Power up PLL with outdiv = 0 then switch to 3
ath_gmac_enet_initialize…
No valid address in Flash. Using fixed address
ath_gmac_enet_initialize: reset mask:c02200
athr_mgmt_init ::done
Dragonfly ----> S17 PHY *
athrs17_reg_init: complete
SGMII in forced mode
athr_gmac_sgmii_setup SGMII done
: cfg1 0x80000000 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
eth0
Qualcomm Atheros SPI NAND Driver, Version 0.1 (c) 2014 Qualcomm Atheros Inc.
MFR:200,DID:177
====== NAND Parameters ======
sc = 0x87ff6230 page = 0x800 block = 0x20000
Setting 0x181162c0 to 0x4b962100
Press reset button for at least:
- 5 sec. to run web failsafe mode
Reset button is pressed for: 5
Button was pressed for 5 sec…
HTTP server is starting for firmware update…
Trying eth0
dup 1 speed 1000
HTTP server is starting at IP: 192.168.1.1
HTTP server is ready!
ARP Retry count exceeded; starting again
Trying eth0
Trying eth0
any ideas how to fix this?
