Running AR750S (Slate) with firmware 3.009, with always on OpenVPN. Works great !
This connects to one of two Access Points. I need to be able to set a priority, say if AP-One is available, use it, if not use AP-Two. If connected to AP-Two, scan periodically to see if AP-One is available and switch to it, if it is available.
The next firmware update seems to have “Scan and Re-Connect” option. Will it be able to provide the above described functionality ?
It appears the Travelmate package would be able to give me this functionality. Is that the recommended way to achieve this ? Any other options ?
Thanks
