@tauceti Could you please upgrade the latest testing firmware? Here is the link to download. Please untick “keep settings” when upgrading, and don’t using luci instead of our webui to connect your upstream AP. Please let me know if this version fixed the issue.
Hi Kyson-lok,
thanks for the reply. It seems to work now. Perhaps it is because of the autochannel feature which is now enabled?
Not sure why, because we can’t reproduce this issue. However, we had fixed some bugs for 5GHz repeater, such as inconsistent bandwidth, channel issue and so on.
I meet with the same problem. I take gl-ar750s-3.006-1104.tar firmware and start with clean configuration: the problem remains. A750S prefectly uses 2.4GHz Wi-Fi as WAN, but fails to use 5GHz WiFi as WAN. I have saved config and logs. Here is my /etc/wireless:
config wifi-device ‘radio0’
option type ‘mac80211’
option channel ‘36’
option hwmode ‘11a’
option path ‘pci0000:00/0000:00:00.0’
option doth ‘0’
option txpower ‘20’
option band ‘5G’
option disabled ‘0’
option legacy_rates ‘1’
option country ‘RU’
option org_htmode ‘VHT80’config wifi-iface ‘default_radio0’
option device ‘radio0’
option network ‘lan’
option mode ‘ap’
option encryption ‘psk-mixed’
option ifname ‘wlan0’
option wds ‘1’
option ssid ‘bordeaux_tr5g’
option key ‘XXX’config wifi-device ‘radio1’
option hwmode ‘11g’
option path ‘platform/qca956x_wmac’
option txpower ‘20’
option noscan ‘1’
option htmode ‘HT40’
option band ‘2G’
option disabled ‘0’
option channel ‘13’config wifi-iface ‘default_radio1’
option device ‘radio1’
option mode ‘ap’
option wds ‘1’
option ifname ‘wlan1’
option ssid ‘bordeaux_tr’
option key ‘XXX’config wifi-iface ‘sta’
option network ‘wwan’
option mode ‘sta’
option ifname ‘wlan-sta’
option encryption ‘psk2’
option key ‘XXX’
option disabled ‘0’
option ssid ‘bordeaux_5G’
option gl_bssid ‘64:09:80:73:D8:38’
option channel ‘36’
option bssid ‘64:09:80:73:D8:38’
Can you give the logs as well?
iwinfo
logread
dmesg
also, how does the country change to RU?
Oops. Sorry. After I post a message, I remember about iptables rules on this network. So it was a probem with my network configuration. Nevermind.
About ‘RU’ country. I suppose that country code survives reset.
so, you confirm that 5G doesn’t have problem?
Yes. Thanks for device.
