I have the following issue:
I have the GL-AR750S with 2 WLANs enabled in 2,5ghz and 5ghz. Lets say SSID: “abc24” and “abc5”
Now I am repeating an external 5GHz WLAN (Mode:Client) (SSID: “external5”) with the GL-AR750S.
Then the network “abc5” is not available(cannot be found) anymore for clients to connect but only the 2,4GHz wlan “abc24”
However It works when repeating an external 2,4GHz network (SSID: “external24”).
Here I can see and connect to both GL-AR750S networks: “abc24” and “abc5”
For me this seems to be a bug?
I want to repeat the external 5GHz network and connect to the GL-AR750 5Ghz “abc5” network to have the max speed
and clients with only 2,4 capable should connect to “abc24”.
The channel of both wlans is 48. For 2,4 GHz it was channel 6. Don’t think that matters.
I don’t want always the same ssid. BEcause in a hotel I don’t want to change the ssid for my clients to the hotel wlan every time and reenter passwords.
So have you understood my issue?
Repeating external/hotel 5GHz wlan to private 5GHz wlan does not work as the private wlan does not show or doesn’t broadcast its ssid. It works with 2,4 ghz though. Can you guys please check the same if it works for you ?
Or do I have to configure something ?
@nopro404: I don’t want the same SSID for 2,4 and 5 GHzbecause then I cannot check if there are really 2 wlans broadcasted…
and as written the 5GHz is not broadcastet or available…
well if the AR750S cannot repeat a 5GHz into another 5Ghz wlan the whole router doesn’t make sense…does it work for you??? @kyson-lok can you please advise?
Understood your issue. For 5G there was a bug to work as repeater when there are a lot of DFS channels around. When this happen you will not connect to the Internet.
Anything new? It is the main usecase I bought the device for. I also tried many settings in LuCI and also resetted the whole device but the 5GHz wlan is only available and visible when I deactivate the repeated 5GHz wlan in LuCI. Do I have a faulty unit?
it is strange. with the latest testing firmware (29.09) I cannot see my 5ghz WLAN when scanning for networks in AR750s router. It is only shown as DFS. Is the channel the issue? my 5Ghz Wlan uses 108 channel.
I retried and found out that the problem must be somehow that I have 2 WLANs (2,4 and 5 GHZ) with the same SSID. When I use only a 5GHZ WLAN with a unique SSID it seem to work
I re-examined: have 2 routers (not GLI fabric) which each send both a2,4 and 5 GHz
WiFi all with the same SSID. I get the above problem with the third Router (which is my AR750) when repeating the 5GHz WiFi but only if both other routers are operating. If I disable one non GLI router it works. Strange.
