In my country we have an operator that uses several free hotspots that can be used if you are a subscriber.
So I have a subscription and would like to make use of the free hotspots that are offered when on vacation.
These hotspots are called ‘TelenetWifree’ (Telenet is a Belgium operator) and are use WPA2 Enterprise to login.
The repeater function with the AR750S Slate works fine, and I’m able to setup a local network, but after a while the AR750S disconnects / is kicked? from the ‘TelenetWifree’ network.
When I restart the wireless antenna connected to the ‘TelenetWifree’ via Luci everything works again, only to again drop the connection after a while…
Is there a way to solve this?
- Why is the connection dropping? Some kind of timeout that the operator has put to avoid abuse of the free hotspots?
- Can the AR750S be configured so it knows when it is beeing dropped so it can restart/reset the connection? (I have auto-reconnect enabled, but this does not seem to work, only a full restart or wireless antenna reset through Luci seems to help.)
Any help?
I’m using my AR750S Slate to repeat an WPA2 Enterprise network
