I recently updated my ar750s to a pure OpenWrt 22.03.2 (downloaded on openwrt.org).
Everything works fine. But when I plug the ethernet cable into the WAN socket, it behaves strangely. It will connect and disconnect from the internet every 10 seconds!
If I connect the internet cable to another socket (LAN), it’ll work fine, but the AR750S behaves like a switch, and the admin page will not open anymore.
The wan and lan work fine in the official GLiNet firmware.
You might start by downgrading to 21.02.5 and see if you have the same problem on the earlier release. There were some significant networking changes in 22.03, so getting a baseline could be useful.
Does the archer have a real IPv4 address (I know my cell provider generally provides only IPv6). Can you see if you have the same results when you ping6 google.com or similar?
my ISP doesn’t provide ipv6 at all. I have an antenna on the roof which receives LTE and send it to the Archer. the archer is as a router as well with 192.168… IP address.
