Whenever I connect the slate to a router, I cant get the wifi to turn on. I cant seem to get it to connect to my laptop to check any of the settings. What could be going on?
Got 2g working. It says 5G is on, but doesnt seem to be activating
Can your PC found other 5GHz WiFi?
Can you post screenshot and logs?
For logs you can ssh to the router and post the output of the following command
ifconfig
logread
I reset the router, and it fixed it
